System too lean bank 1, can't find mechanic to help - Chevy Impala Forums
post #1 of (permalink) Old 11-11-2013, 07:00 PM Thread Starter
jgbride's Avatar
I've been dealing with p0171,system to lean bank 1 ,for 6 months now. I have a 2000 impala ls 3.8 with 119k miles. The car runs like a charm without any hesitation what so ever which isn't like some cars I've heard about with this code. Anyway here is what's been done , new fuel filter, new mass air sensor , new upstream oxygen sensor, been on several different obdII scan tools and reset numerous times but this code comes back very fast every time. Now I know intake manifold gaskets are weak on these cars I've had a mechanic try to find vacuum leaks without luck and try the cabortator cleaner spray trick around the intake without luck. The mechanics I talk to don't sound interested in changing intake gaskets and plenum. Any suggestions? In my county we have emissions inspection and vehicles will not pass with the check engine light on no matter what code it is. Thanks guys
jgbride is offline
post #2 of (permalink) Old 11-11-2013, 07:23 PM
auntjemima's Avatar
Ontario eh?.. wonderful province
Have you changed your air filter by chance?
auntjemima is offline
post #3 of (permalink) Old 11-11-2013, 08:32 PM
77Impala's Avatar
Quoted: 6 Post(s)
Brake booster leaking? If so it would allow way to much air into the intake and be a hard vacuum leak to find with carb spray.
Vacuum hose that connects the MAP sensor if it has cracks it will allow to much air. Only way to tell is to remove the sensor from the back side of the UIM and check the hose.
77Impala is offline
post #4 of (permalink) Old 11-13-2013, 02:28 PM Thread Starter
jgbride's Avatar
Actually I live in North Carolina I hate emissions testing, anyway yes I have changed my air filter pretty recently. I'm not sure about my brake booster I will check I have had my map sensor off to check my pcv valve but haven't really checked for a leak there I will look into it Would a faulty map sensor cause this code?
jgbride is offline
post #5 of (permalink) Old 11-13-2013, 05:28 PM
77Impala's Avatar
Quoted: 6 Post(s)
No it would not since the lean condition is only on one side of the engine. This is a vacuum leak of some sort.
77Impala is offline
P0172 "Fuel Trim System Rich Bank 1" Walter89 Autocare and Maintenance 0 03-12-2012 08:12 AM
Too Lean? ejeezy_23 Chevy Impala 7th Gen Discussion 1 08-19-2011 11:19 AM
running lean? DrewImpala Chevy Impala 7th Gen Discussion 2 07-11-2011 12:52 PM
Lean codes help 96impala 6th Gen Engine Performance 0 06-29-2010 11:38 AM
system too lean? o2 sensor heater malfunction? clone 96 Mechanical and Electrical Problems 1 08-20-2008 09:12 PM
