Squeak and clunk under hard breaking. - Chevy Impala Forums
post #1 of (permalink) Old 07-29-2013, 03:18 PM Thread Starter
auntjemima's Avatar
Ever since I threw on a front strut tower brace and the brackets from Don Rome my impala has been clunking and squeaking in the front end.
I checked tie rods, ball joints and sway bar links. All are at proper torque and under allowable play.
Sway bar bushings looks good.
My question is obviously what's causing it or suggestions but also I am curious if the transmission can cause this problem? I ask because as you break hard the wheels are connected through the CV axle to the internals... Can this cause any ill effects as hard acceleration can?
auntjemima is offline
post #2 of (permalink) Old 07-29-2013, 05:08 PM
I'd imagine you probably have, but have you checked motor mounts, tightness of the STB mounts, and brake pads and calipers?
post #3 of (permalink) Old 07-29-2013, 05:35 PM Thread Starter
auntjemima's Avatar
i checked all of the above. I am going to remove my stb bar tomorrow and see what happens. I dont see it causing my issue but it started shortly after install.
post #4 of (permalink) Old 07-30-2013, 09:49 AM Thread Starter
auntjemima's Avatar
After rechecking everything from all angles I have decided its likely my sway bar bushings. The mounting hemisphere is slightly twisted and the bushings are starting to come out of the metal sleeve.
post #5 of (permalink) Old 07-30-2013, 11:18 AM
GTXKen's Avatar
Makes sense, common cause for clunking front ends for many makes and models
GTXKen is offline
Strange Squeak from front kevin 8th Gen Suspension 24 10-26-2012 11:36 AM
Annoying squeak Z71 Chevy Impala 8th Gen Discussion 12 09-08-2012 07:56 AM
Hell breaking loose Crime Scene Off-Topic Discussion 12 12-05-2011 09:47 AM
hopped curb, now wierd click (or thump) (or clunk) hard to describe tommymac23 8th Gen Suspension 9 02-20-2011 10:26 PM
I keep breaking the carrier bearing BigRedSleeper 1st - 5th Gen Drivetrain 12 10-20-2008 10:54 AM
