Question about DRL on 01 impala. - Chevy Impala Forums
post #1 of (permalink) Old 07-03-2013, 07:49 PM Thread Starter
Mikey7436's Avatar
Quoted: 5 Post(s)
I have a 01 impala and I was wondering where the daytime running lights wires go. Like starting at the sensor on the dash. Where does it go and plug in from there. I believe it came unplugged since my DRL do not work.
Mikey7436 is offline
post #2 of (permalink) Old 07-06-2013, 12:43 PM
g25racer's Avatar
It's likely just a dirty or bad sensor
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
Thunderbolt Spun Cat
ZZP Alternator Power Cable
Wagner Thermoquiet Pads
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Dipped Rims and emblems
JBL GTO 6.5" and 6x9"
Sony MEX-GS600BT
Rockford P3 @ 500rms
g25racer is offline
post #3 of (permalink) Old 07-07-2013, 05:22 AM
fastcat's Avatar
Once u find out please post location of the sensor so I can unplug mine. Lol, I figure if my lights are on in the daytime I wasting the bulbs life.
fastcat is offline
post #4 of (permalink) Old 07-07-2013, 06:11 AM
auntjemima's Avatar
You aren't.
But the sensor is located at the front of the dash, near the vents. It's that little black glass bulb.
auntjemima is offline
post #5 of (permalink) Old 07-07-2013, 07:42 AM
Quoted: 273 Post(s)
I think that he was looking for the location where the sensor "plugs in", not the location of the sensor itself... Sounds like he wants to disconnect it so that the DRL don't work anymore...
For the price of the bulb, I'd personally leave them plugged in - one benefit of DRL's is that you don't have to worry about getting a ticket if you drive through a construction zone without your headlights being on! :-) At least here in Pennsylvania, your must turn on your headlights when driving through a construction zone or else you can get a hefty ticket!
post #6 of (permalink) Old 07-07-2013, 08:13 AM
OEM LOL
Ejbiers's Avatar
Never heard of anyone getting a fine for not turning their headlights on and it's only a secondary offense you can't be pulled over for it. Also drl don't count.
(Let's try not to talk out of our asses when giving advice brah)
http://forums.officer.com/t96610/
You can pull the drl fuse to disable them
If they aren't working try cleaning the globe first as suggested. If that doesn't work then trace the wires from the globe to where ever you find a plugs.
2016 Mustang GT PP Premium
Know the truth
http://infowars.com
Ejbiers is offline
post #7 of (permalink) Old 07-07-2013, 08:43 AM
Quoted: 273 Post(s)
My bad! Sorry for the misinformation! Thanks for the clarification. Also didn't realize that it was only a $25 ticket! I guess that the ticket would be cheaper than replacing the bulbs more! :-)
In all seriousness though, can you actually tell the difference between DRL's and "normal" headlights in the middle of the day? Are they really that "different"? I always thought (incorrectly, obviously) that DRL's were the same as the "normal" headlights. Are DRL's actually using different bulbs alltogether or do they use the same bulbs, just at a different brightness?
post #8 of (permalink) Old 07-07-2013, 12:06 PM
OEM LOL
Ejbiers's Avatar
The drl run at less of a voltage than your regular headlights so they virtually don't use up any life of your bulbs.
Also your taillights nor marker lights are on with your drls.
Know the truth
http://infowars.com
Ejbiers is offline
The Following User Says Thank You to Ejbiers For This Useful Post:
jtrosky (07-07-2013)
post #9 of (permalink) Old 07-07-2013, 06:53 PM
Quoted: 51 Post(s)
I think there's a lot of confusion going on here. We are talking about an 01 impala. The drls and headlights are SEPARATE bulbs, although the drl and high beams use the same bulbs. You can NOT disable the drls by pulling the fuse.
Also, a lot of guys spent a lot of time trying to figure out how to disable drls on the 7th gen without getting the bulb out message or the auto headlights turning on, to no avail.
Do your headlights come on automatically when you start the car, or do you have no lights until you turn them on?
*2001 Impala Ls - 129k
*2000 Blazer 4x4 - 174k
Winter daily
*1977 C10 - Work in progress
*2014 Impala LT Limited - 35k
RYD SLO is offline
post #10 of (permalink) Old 07-07-2013, 07:11 PM
g25racer's Avatar
I believe there is a way to disable the drl's. It is possible on monte's and impala's have a very close setup as them.
Others have also said to bend over a pin on the relay.
Not sure if either have been tested on a 7th gen imp but, it could work.
Also with 05 monte's all you have to do is pull the fuse/relay. No messages pop up at all.
disable DRL's with pictures!! - Monte Carlo Forum - Monte Carlo Enthusiast Forums
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Sony MEX-GS600BT
g25racer is offline
post #11 of (permalink) Old 07-07-2013, 07:14 PM
auntjemima's Avatar
Personally, my DRL's don't come on until I take the vehicle out of park.
04.
post #12 of (permalink) Old 07-07-2013, 07:16 PM
Quoted: 51 Post(s)
I believe the relay trick only works on 2005s
On 00-04 they still come on even with the pin bent.
Winter daily
RYD SLO is offline
post #13 of (permalink) Old 07-07-2013, 08:56 PM
Quoted: 273 Post(s)
Interesting - and to think that someone just advised us that you can just "pull the fuse" to disable DRL, while at the same time informing me that we shouldn't "talk out of our asses when giving advice" in the very same post! Hmm... :-)
g25racer (07-07-2013), RYD SLO (07-07-2013)
post #14 of (permalink) Old 07-07-2013, 08:58 PM
Quoted: 51 Post(s)
Winter daily
RYD SLO is offline
post #15 of (permalink) Old 07-07-2013, 09:03 PM
g25racer's Avatar
^^ That's funny but, I think he somehow thought u were talking about 8th gens. That or he just doesn't know 7th gens like he thinks he does. No offense Ej .. aka brah
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Sony MEX-GS600BT
g25racer is offline
Disable DRL...the $1.50 solution. thespottedgopher "DIY" Do it yourself/how to 16 09-07-2015 01:19 PM
DRL Relay 001impala Chevy Impala 7th Gen Discussion 32 02-10-2013 09:25 AM
2005 hid drl PoochDawg Chevy Impala 7th Gen Discussion 1 12-25-2010 11:46 AM
2008 Impala SS DRL's hounddog Chevy Impala 8th Gen Discussion 1 02-01-2010 12:09 PM
HIDS and DRL Problems Impala08 Chevy Impala 8th Gen Discussion 2 11-29-2009 05:04 PM
