Change transmission fluid? - Chevy Impala Forums
post #1 of (permalink) Old 05-13-2013, 07:58 PM Thread Starter
pt80chip's Avatar
Just curious to know what the consensus is on changing the transmission fluid.
My 01 Impala has 67k miles on it but I know it overheated a few times with the previous owner. I don't know if the fluid was ever changed but since the ATF is cooled by the radiator, engine overheating means this fluid was also overheating.
I've read horror stories about people changing their fluids only to find new problems. I also heard of people not changing their fluid and paying the price because of it.
Any thoughts?
2002 Chevy Impala 3.4L - Black
2001 Chevy Impala 3.8L - Blue
pt80chip is offline
post #2 of (permalink) Old 05-13-2013, 09:21 PM
SCOTTYINWV's Avatar
Most people who have problems after a fluid change was either due to lack of previous maintenance (not changing when needed/recommended) or they flushed the system, which is a transmission killer. Drop the pan, change the filter and pan gasket, and top off the fluid with recommended fluid.
SCOTTYINWV
SCOTTYINWV is offline
post #3 of (permalink) Old 05-13-2013, 09:29 PM
SuperDave's Avatar
Send a message via AIM to SuperDave
Normal trans temps should be around the 180-200* area, just because the motor over heated does not necessarily mean the trans also did. You shouldnt have any problems changing out the fluid, especially only at 67K.
2001 Impala 9c1: SLP CAI: L67 coils:PRJ wires:ZZP volt booster:Fuel pump rewire:Trans cooler:HD diff/axle:Home made Shift kitrilled 180* Tstat:Flipped MM's:GTP dual exhaust:Aero force scan gauge:Whelen 90watt Strobes front/back wig wag reverse lights:Whelen air horn:Wig wag headlights.
SuperDave is offline
post #4 of (permalink) Old 05-13-2013, 09:34 PM
SCOTTYINWV's Avatar
Did you get your fixed Dave?
SCOTTYINWV
post #5 of (permalink) Old 05-13-2013, 09:57 PM Thread Starter
pt80chip's Avatar
True, but the car exceeded 240 degrees. I've had overheating issues on my other impala (head gasket related) and I decided to change the atf after that. Instead of being red it was brown in color.
pt80chip is offline
post #6 of (permalink) Old 05-13-2013, 10:02 PM
SuperDave's Avatar
No, trans is out and I have to swap the harness to the new one. Should be going in and be done tomorrow hopefully.
Chip, I seriously wouldnt worry about it, It would take a long time for the trans to over heat, even when the engine is.
post #7 of (permalink) Old 05-13-2013, 11:28 PM
SCOTTYINWV's Avatar
Exactly, I would change the fluid though, just for routine maintenance...
And good luck with the swap dave. Start a thread and provide pics
SCOTTYINWV
post #8 of (permalink) Old 05-14-2013, 09:09 AM
67k and you don't know the history, just go ahead and change it, it won't hurt.
post #9 of (permalink) Old 05-14-2013, 07:04 PM
BigCee's Avatar
BigCee is offline
post #10 of (permalink) Old 05-16-2013, 01:28 AM
g25racer's Avatar
Originally Posted by BigCee View Post
And the filter too while you're at it.
Should always be done when replacing fluid
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
Thunderbolt Spun Cat
ZZP Alternator Power Cable
Wagner Thermoquiet Pads
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Dipped Rims and emblems
JBL GTO 6.5" and 6x9"
Sony MEX-GS600BT
Rockford P3 @ 500rms
g25racer is offline
The Following User Says Thank You to g25racer For This Useful Post:
kingnutin (05-16-2013)
post #11 of (permalink) Old 05-19-2013, 06:48 PM
The Man In Black
Moses's Avatar
Not if you take it to a shop for the flush. The flush cleans the filter.
To OP. At 67k miles you will be fine. Our transmission guy has been working there for 18 years and specializes transmissions by choice. He even told me my car is on the borderline for flushing. He also informed me that GM highly recommends using dexron VI instead of III. Especially in the 4t65e and hd's.
05 Impala LSS 3800 Series II L36 A4 - Daily Driver
Short Ram Intake, ZZP TB Spacer, ZZP HV3, Flowmaster 40, ZENEX HID Headlight kit, Red ACCEL Plug-Wires, Extended IAT Sensor, Tinted Foglights/Taillights, Speed Daddy Headers, Magnaflow Hi-flow Converter, 180 T-stat.
07 Impala SS LS4 A4 - Wife's car
Completely stock
96 Firebird Formula 5.7L 350 LT1 M6 - Sold
Moses is offline
post #12 of (permalink) Old 05-19-2013, 06:50 PM
SCOTTYINWV's Avatar
Flush = transmission failure, I NEVER would...
Not changing the filter is a lazy way out of a job, period...
SCOTTYINWV
post #13 of (permalink) Old 05-19-2013, 07:29 PM
The Man In Black
Moses's Avatar
K cool. Just stating what GM certified service(used to be goodwrench) states.
Completely stock
Moses is offline
The Following User Says Thank You to Moses For This Useful Post:
SCOTTYINWV (05-19-2013)
post #14 of (permalink) Old 05-19-2013, 10:16 PM
g25racer's Avatar
For the most part they are blowing smoke up your (you know what). A fush w/o a filter change after just removes and sloshes around the small metal shavings that were trapped in your filter. Totally defeating the purpose if a filter Therefor, unless it is flushed then fluid and filter changed it is NOT recommended
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Sony MEX-GS600BT
g25racer is offline
post #15 of (permalink) Old 05-20-2013, 05:32 AM
GTXKen's Avatar
I have made it a habit to change trans fluid, diff and coolant every 3 years regardless of the mileage. Maybe thats a bit excessive but when you consider the costs it is really cheap compared to the cost of replacing major components.
As far as flush vs change goes....since I do mine periodically the fluid left in the system in a change is minimal so it stays pretty clean. I did have my old Durango flushed before and I really can't say anything bad about it. Again since I service it frequently the filter was changed the next time around so flushing was fine every other time and is so much faster to have done.
When I change my trans fluid the first time I always install a drain plug so the next time around its not nearly such a messy job.
GTXKen is offline
Do I use hydraulic fluid or transmission fluid in my convertible top motor? kilgore87 Restoration Forum 11 11-25-2012 04:22 PM
trans fluid change with fluid evacuator? child_of_fire Chevy Impala 7th Gen Discussion 4 08-15-2012 12:58 PM
2004 Impala - Transmission issue after fluid change! LordX Chevy Impala 7th Gen Discussion 17 12-09-2011 10:26 AM
Transmission fluid change aztecs2006 Chevy Impala 7th Gen Discussion 1 07-17-2011 04:48 PM
91 Caprice SW Transmission Fluid Change How Remove Bolt radiumglow Chevy Caprice 0 05-23-2010 01:42 PM
