Traction and ABS lights help - Chevy Impala Forums
post #1 of (permalink) Old 04-05-2013, 02:57 PM Thread Starter
GTXKen's Avatar
So I'm down in Florida picking up a 2002 impala with 40,000 on it. I have no way to read codes. The traction control is off and the ABS light is on. When you start the car it says service traction control system.
Can anyone make an educated guess for me?
Thanks
Ken
GTXKen is offline
post #2 of (permalink) Old 04-05-2013, 04:27 PM
impala_'s Avatar
Thanks
Ken
could be:
the wiring harness
bad sensor (requires wheel hub replacement. since the sensor is not a replaceable part)
Bad sensor is a very common issue replacement is $80 to $150 depending on where you go.
impala_ is offline
post #3 of (permalink) Old 04-05-2013, 04:36 PM
auntjemima's Avatar
Likely a bad sensor as mentioned. The traction control and abs are pretty much one in the same and use the same sensors to do their business.
It's completely safe to drive without the TCS or ABS.
auntjemima is offline
post #4 of (permalink) Old 04-06-2013, 04:56 AM Thread Starter
GTXKen's Avatar
Thanks. I can change hubs. If I use the scan tool when I get home will it tell me which hub?
GTXKen is offline
post #5 of (permalink) Old 04-06-2013, 02:54 PM
05LS's Avatar
Thanks
Ken
My car has the same lights on. I took it to pep boys and they said I should take it to the dealer. They couldn't pinpoint the exact cause but scanned the codes and came up with:
c1216 ebcm, c1218 abs pump motor, c1221 If wheel speed sensor, c1222rf wheel speed sensor, c1226 rf wheel speed sensor, c1233 rf wheel speed sensor, c1245 low tire pressure....basically they said it may be a wiring issue or possible bad ebcm.
I honestly haven't fixed it's been about 5 months. It drives fine. The lights are annoying though.
05LS is offline
post #6 of (permalink) Old 04-06-2013, 03:17 PM
Carnegie's Avatar
Pretty much the same thing as 05LS And, yeah the lights and bells are annoying..anyway to override that?
Carnegie is offline
post #7 of (permalink) Old 04-06-2013, 10:57 PM
impala_'s Avatar
None of that maybe the issue have you tried filling up the tires? and reseting it?
Assuming you still have the useful factory radio installed
1. Turn Ignition on and turn radio off Very important not to start the engine or this will not work.
2. Press and hold DISPLAY on the radio until SETTINGS is displayed.
3. Use SEEK , scroll until TIRE MON appears
4. Press Prev or Next till RESET is displayed.
5. Press SEEK button.
6 Exit
Traction control is just electronic controlled differential .
off is not locked( depending on manufacture setting)
on limited slip variable electronic controlled.
ABS prevents the breaks from locking up when you press them hard. This helps the car stop faster.
both traction control & ABS use the sensor(s).
Yes it will. If it does not you could just search the code on the internet.
impala_ is offline
post #8 of (permalink) Old 04-07-2013, 01:06 AM
g25racer's Avatar
I also had this same problem. If the pump and ebcm codes show up your ignition switch is likely at fault. I just hope the faulty ignition switch didn't take out your ebcm (brake control module) and abs pump. It did on mine. Common problem. When an ignition switch starts to fail it send spikes of voltage to various components and can burn them up. I would get it fixed ASAP before it creates big problems like I had.
To be honest it sounds like you guys are already too late and your ebcm is done for.
A local dealer replaced my EBCM, Ignition switch, and cylinder for a wopping $1,250. It's not something you can do yourself. You could but the ebcm is $500-700 alone, ignition switch and cylinder is around $100, along with a "dealer only" abs brake setup of about $100 or so. You can only bleed the abs system of brake fluid with a tech 2 scanner.
Edit: If you have abs sensor codes along WITH the abs pump and ebcm do NOT just go and replace hubs. The fault is likely at the ebcm, pump, or ignition switch. You WILL be replacing the wrong parts and wasting money. When an EBCM fails and throws codes, so will your abs sensors.
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
Thunderbolt Spun Cat
ZZP Alternator Power Cable
Wagner Thermoquiet Pads
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Dipped Rims and emblems
JBL GTO 6.5" and 6x9"
Sony MEX-GS600BT
Rockford P3 @ 500rms
g25racer is offline
post #9 of (permalink) Old 04-09-2013, 08:37 AM Thread Starter
GTXKen's Avatar
Read codes when I came home today and the only code I got was 0420 for the cat/02 sensor. I assume that I need to go somewhere and have codes read now for the traction and ABS. I'll try my local autozone first I guess. I did the scan with the car not running and the ign on. Any other suggestions to pull codes?
GTXKen is offline
post #10 of (permalink) Old 04-09-2013, 09:44 AM
auntjemima's Avatar
alot of readers wont pick up abs or body codes.
post #11 of (permalink) Old 04-09-2013, 12:25 PM Thread Starter
GTXKen's Avatar
Just got back from Autozone, DS front hub sensor
GTXKen is offline
post #12 of (permalink) Old 04-09-2013, 10:33 PM
g25racer's Avatar
^^ Check wires and connector first.
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Sony MEX-GS600BT
g25racer is offline
post #13 of (permalink) Old 04-09-2013, 10:51 PM
impala_'s Avatar
ouch 1400 or so to fix that
If you do not mind how much was the impala?
impala_ is offline
post #14 of (permalink) Old 04-09-2013, 10:53 PM
g25racer's Avatar
^^ Huh? 1400 to fix what?
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Sony MEX-GS600BT
g25racer is offline
post #15 of (permalink) Old 04-09-2013, 11:01 PM
impala_'s Avatar
P0420
$1400 is for a factory replacement , replacement cost is depending on the state emissions requirements. Some states require factory emissions equipment, other wise it's automatic fail.
impala_ is offline
LinkBack to this Thread: http://www.impalaforums.com/chevy-impala-7th-gen-discussion/341400-traction-and-abs-lights-help.html
c1218 abs code This thread Refback 11-24-2015 07:25 PM
Traction and ABS lights help - Chevy Impala Forums This thread Refback 05-20-2015 06:06 AM
Traction and ABS lights help - Chevy Impala Forums This thread Refback 04-23-2015 10:02 AM
Half working tail lights, no stop lights Mici Mechanical and Electrical Problems 3 02-20-2013 05:33 PM
smoked head lights and tail lights adamg38671 Recent Mods/Weekly Updates 49 05-27-2012 05:32 PM
ABS and Traction Control lights on? unioncreek Mechanical and Electrical Problems 2 03-19-2011 11:40 AM
ABS and Traction Control lights on? unioncreek Chevy Impala 7th Gen Discussion 3 02-01-2011 12:48 PM
1967 Impala Fender Lights/Corner Lights? Matt L Chevy Impala Discussion 1 12-03-2007 04:16 PM
