2004 Impala hard to start - Chevy Impala Forums
post #1 of (permalink) Old 04-02-2013, 06:20 AM Thread Starter
mmanter's Avatar
My dad has a 2004 Impala that is hard to start, and once it starts does not want to stay running when you let off the gas. He told me it's been harder to start lately but would clear out & run alright if he revved it a few times. This morning it would run but once he got off the gas pedal the car would die. Eventually he was able to get the car to start & stay running but it was not very responsive, and had a little bit of a missfire when revving. At idle the car sounded rough but not to the point where it was down a cylinder.
The car does need an EGR valve & has about 130k on the clock. He thinks the plugs might be fouled out and is going to replace them but I'm concerned as to what caused it. When he was able to get the car started he had to hold the pedal to the floor to get the car to start. I'm thinking that indicates the car is dumping too much fuel but not too sure since I wasn't able to diagnose it at all.
Any ideas as to what to look for?
Matt Manter
2004 Impala
mmanter is offline
post #2 of (permalink) Old 04-03-2013, 02:24 PM
jrd0304's Avatar
How do you know you need an EGR valve? Are you getting a check engine light? Any trouble codes when you scan the PCM? In general, I've found EGR failure to be pretty uncommon on these things. Have you tested the fuel pressure at all? If it's too low, the pump may be failing, and if it's too high, the pressure regulator may be going, and neither one specifically would probably give you a trouble code, but the side effects of either one of those failures may.
jrd0304 is offline
post #3 of (permalink) Old 04-03-2013, 09:16 PM Thread Starter
mmanter's Avatar
He drove the car over to the auto parts store & there were three codes stored in the computer for the EGR valve. The car has had the check engine light on for over a year & it was for the EGR valve. Haven't checked the fuel pressure yet but he is wanting to replace the bad valve before attempting any other repairs/diagnosis
Matt Manter
2004 Impala
mmanter is offline
post #4 of (permalink) Old 04-03-2013, 09:30 PM
Storm Trooper Ralf
MixedImpala04's Avatar
How about u clean the egr first before you go throwing a new one at it.
MixedImpala04 is offline
post #5 of (permalink) Old 04-04-2013, 12:02 PM
agmc4me's Avatar
Hi I have a 2004 3.8 impala. I had the MAF go bad and it would not stay running. You COULD floor it and it would run but on the limiter and that blew out the cat. I only wish someone would have told me I could just disconnect the MAF and it would run. Really I just disconnected the MAF and the car ran fine but with a code. It went from undrivable to drivable. This is just info for you to keep in mind might save someone a tow someday. I got lucky and left the car and did some internet research and decided to go back to the car and try that idea before calling a tow truck. glad I did.
agmc4me is offline
post #6 of (permalink) Old 04-04-2013, 11:56 PM
SuperDave's Avatar
Send a message via AIM to SuperDave
Take out the IAC and clean it up, a gunked up IAC will cause a hard start if it gets really bad. Clean it up and it should help out with the hard starts.
2001 Impala 9c1: SLP CAI: L67 coils:PRJ wires:ZZP volt booster:Fuel pump rewire:Trans cooler:HD diff/axle:Home made Shift kitrilled 180* Tstat:Flipped MM's:GTP dual exhaust:Aero force scan gauge:Whelen 90watt Strobes front/back wig wag reverse lights:Whelen air horn:Wig wag headlights.
SuperDave is offline
post #7 of (permalink) Old 04-05-2013, 12:17 AM
g25racer's Avatar
Disconnecting the MAF is NOT a good idea at all
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
Thunderbolt Spun Cat
ZZP Alternator Power Cable
Wagner Thermoquiet Pads
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Dipped Rims and emblems
JBL GTO 6.5" and 6x9"
Sony MEX-GS600BT
Rockford P3 @ 500rms
g25racer is offline
post #8 of (permalink) Old 04-05-2013, 12:30 AM
SuperDave's Avatar
You can unplug the MAF and drive it, doing so will set the PCM into a default MAF setting. I wouldn't go driving it for to long like that though.
post #9 of (permalink) Old 04-05-2013, 12:44 AM
g25racer's Avatar
I knew it would throw a code but, didn't know the pcm would do that. Hmm weird. You would likely have poor gas mileage and perf though, right? The maf readings vary (obv) so, what does the pcm do? Just give a consistant reading?
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Sony MEX-GS600BT
g25racer is offline
post #10 of (permalink) Old 04-05-2013, 12:52 AM
SuperDave's Avatar
Yes, It pretty much sets the fuel trims, trans and ignition settings into default mode.
post #11 of (permalink) Old 04-05-2013, 01:05 AM
g25racer's Avatar
Gotcha. So def not something you'd want to do for a long period of time. Sort of a fail safe, if you will.
Thanks for the info I am still learning many new things
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Sony MEX-GS600BT
g25racer is offline
post #12 of (permalink) Old 04-05-2013, 07:39 PM
RustMcNutz's Avatar
Hi Guys
New here but try your Crank Position Sensor goes bad and sometimes will not show a code. Causes poor starting cuting out or a no start situation.
Rusty
RustMcNutz is offline
2004 Impala Hard Start Aaron65 Chevy Impala Discussion 0 06-20-2012 09:00 AM
Occasional hard start?? Help me Tonyman89 Chevy Impala 7th Gen Discussion 6 08-24-2011 12:22 PM
hard start.... mlee19841 Automotive Discussion 7 09-02-2010 04:16 PM
Hard Start (wits End) cheven Autocare and Maintenance 11 11-29-2009 11:36 PM
Hard cold start Bjpz28 Chevy Impala 6th Gen Discussion 15 09-15-2009 02:00 PM
