2005 impala dash lites - Chevy Impala Forums
post #1 of (permalink) Old 03-24-2013, 06:45 AM Thread Starter
Carnegie's Avatar
Hey guys and gals. 2005, 3.4 with 171,000 kms. I have issues with my abs and traction control lites coming on. I know it is a sensor somewhere, it's a guessing game. Used to come on when the car got wet, then progressed to coming on as soon as I put the car in drive. Now, the lower left side red "brake " icon will lite up occasionally. Sometimes immediately, sometimes after 5 minutes, sometimes after 25 minutes or so. Brakes feel fine, but obviously there is an issue. Do not want to sink a lot of money age and mileage are a concern. But otherwise, it is a good car...any ideas?
Carnegie is offline
post #2 of (permalink) Old 03-24-2013, 07:53 AM
Back in Black
12ltz's Avatar
Probably wire harness going to your wheel hub check for damage on wires and socket where they plug into the hubs. Could be wheel hub going bad or the sensor in hub going bad. Dealer or a good shop should be able to tell you which one or ones are bad.
check out search on forum lots of threads on this.
Good luck
_________________________
2012 Impala LTZ 72,000 miles
12ltz is offline
post #3 of (permalink) Old 03-24-2013, 11:52 AM Thread Starter
Carnegie's Avatar
Thanks for the quick reply. Just changed both my wheel bearing hubs in the front myself, and saw no frayed or cracked wires. Did the same cursory check in the rear, with nothing visible. I kinda figured I would have to go and have it scanned. Just hoping for an easy fix. (wouldn't that be nice once in a while? Ha ha )
Carnegie is offline
post #4 of (permalink) Old 03-24-2013, 12:36 PM
jim1405's Avatar
x2 on checking the harness. It can still be bad but not show any visible damage. Find an auto parts store that will scan abs codes for free to determine which wheel is throwing the error and then check that harness with an ohmmeter. Chevy issued a technical service bulletin about the harness being too short and/or rubbing against other parts. My right front harness was bad, got one from rockauto.com delivered for about 35 bucks and it was a simple fix.
jim1405 is offline
post #5 of (permalink) Old 03-26-2013, 01:41 AM
g25racer's Avatar
^^ All great advice and very true. The abs harnesses are common to fail due to GM's mistake, esp the front one's. But, the abs sensor's/hub's are also a regular maint thing. After about 100-140k miles they tend to become worn out or dirty. All abs sensors are magnetic sensors so, if a small particle of iron/steel gets stuck on them, it tends to result in a replacement hub. Most of these abs sensor are non-serviceable which means, replacing the whole hub. Whenever you have an abs problem, inspect abs harnesses, clean terminals, and apply dielectric grease. Then, unhook battery for 10 min while key is ON. Then, start car and drive for a bit to see if light/s disappear. If not, take to a local shop or autoparts store that has an ABS CAPABLE OB2 SCANNER. Have a scan done to find the correct corner/area.
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
Thunderbolt Spun Cat
ZZP Alternator Power Cable
Wagner Thermoquiet Pads
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Dipped Rims and emblems
JBL GTO 6.5" and 6x9"
Sony MEX-GS600BT
Rockford P3 @ 500rms
g25racer is offline
weld drag lites! box_chevy_boy Wheels and Tires 2 01-04-2011 03:37 PM
Chevrolet : Impala Impala stationwagon,hide-a-way lites,protect-o-plate RSS Bot eBay Cars For Sale: Impala 0 07-15-2010 09:20 AM
I own a 2005 Chevrolet Impala trouble with dash panel gages, (gas,speedometer,temp.)? Javier G Mechanical and Electrical Problems 1 09-15-2008 06:58 PM
Can I put a in-dash navigation system in my 2005 Impala? lelani Chevy Impala Discussion 1 08-19-2008 01:43 PM
what would be better a 2005 chevy impala or a 2005 suzuki forenza? Slik 420 Chevy Impala Discussion 0 03-24-2008 12:26 PM
