New Motor Mounts? - Chevy Impala Forums
post #1 of (permalink) Old 02-13-2013, 02:33 PM Thread Starter
tjeick's Avatar
New Motor Mounts?
I noticed this summer that one of of my upper motor mounts has a small crack in it, and recently I've noticed some other weird stuff too.
The engine seems to produce a squeak when I hit a bump, like the mounts are protesting in their old age (we recently passed up 160k and 13 years). Also, at low rpms, the whole thing shakes, especially after my long drives to and from college.
I understand the shaking may be the torque converter or even the transmission, but that's on a long list of repairs anyway. My concern now is if I need to replace those motor mounts immediately to avoid more complications or if they can sit till the summer when I can more comfortably afford that repair.
J.
2000 LS 3.8 with fair share of problems.
Only 18, just learning to love my car.
tjeick is offline
post #2 of (permalink) Old 02-13-2013, 03:09 PM
OEM LOL
Ejbiers's Avatar
I'd replace them they are cheap it's like $25 for a brand new pair.
And the shaking is prolly the broken motor mount.
2016 Mustang GT PP Premium
Know the truth
http://infowars.com
Ejbiers is offline
post #3 of (permalink) Old 02-14-2013, 10:00 AM
The lower mounts effect that much more than the uppers, the upper mounts are more for stability.
post #4 of (permalink) Old 02-14-2013, 10:57 AM Thread Starter
tjeick's Avatar
Are the lower ones something I could manage on my own or should I have them do that while they rebuild my trans?
J.
tjeick is offline
post #5 of (permalink) Old 02-14-2013, 11:13 AM
Back in Black
12ltz's Avatar
if they are doing new trans have them replace while they are there if they are worn badly
_________________________
2012 Impala LTZ 72,000 miles
12ltz is offline
post #6 of (permalink) Old 02-14-2013, 11:18 AM
Jpsycoboy5's Avatar
Cheap solution for the mean time fill the upper mounts with window weld it makes it like a solid mount
2003 Impala LS 3800, Modified stock air box, rear stb, DIY hardware shift kit, flipped motor mounts, and 55w hids in projector headlights.
Jpsycoboy5 is offline
post #7 of (permalink) Old 02-14-2013, 02:17 PM Thread Starter
tjeick's Avatar
I called a shop for a quote on my trans rebuild and replacing the lower mounts, and they told me they'd put the mounts on for free with the rebuild (a reasonable 1750).
Then they told me the mounts themselves would cost an extra 200. WUT. I thought they were like 25 apiece, and there's only three on the bottom, right? Am I missing something here, or is two bills for those mounts just ridiculous?
J.
tjeick is offline
post #8 of (permalink) Old 02-14-2013, 02:20 PM
OEM LOL
Ejbiers's Avatar
Bottom mounts are more expensive than the top ones
How do you know your trans is bliwn?
Know the truth
http://infowars.com
Ejbiers is offline
The Following User Says Thank You to Ejbiers For This Useful Post:
tjeick (02-14-2013)
post #9 of (permalink) Old 02-14-2013, 02:27 PM Thread Starter
tjeick's Avatar
I have another thread all about that, but basically the clutches are worn out and their graphite is floating about my fluid, it has trouble shifting, especially when hot, and fourth gear is gooooone.
J.
tjeick is offline
post #10 of (permalink) Old 02-14-2013, 02:36 PM
OEM LOL
Ejbiers's Avatar
Oh then yeah iys done
I thought you just thought the shaking means your trans was shot lol
Just looking out for ya!
Know the truth
http://infowars.com
Ejbiers is offline
tjeick (02-14-2013)
post #11 of (permalink) Old 02-14-2013, 04:25 PM
There are two lower mounts, I would just buy them yourself and give them to the shop when you take the car in. I know the motor mount is only like $20 on rockauto, I think the trans mount is a little more, but not that much.
tjeick (02-15-2013)
post #12 of (permalink) Old 02-15-2013, 02:02 AM
g25racer's Avatar
Good luck finding the upper engine mounts. What mount is it? It is the cast aluminum one that mounts to the block correct? If it's the passenger one you are most likely better off finding an l67 (3.8 supercharged) than trying to find an l36 as they are kinda hard to find. Just be sure to get the adapter plate for the coil packs. The l67 mount is MUCH stronger as it is cast iron and is much easier to bolt on. Your cracked mount will likely fail in do time if you launch it hard sometimes, like I do.
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
Thunderbolt Spun Cat
ZZP Alternator Power Cable
Wagner Thermoquiet Pads
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Dipped Rims and emblems
JBL GTO 6.5" and 6x9"
Sony MEX-GS600BT
Rockford P3 @ 500rms
g25racer is offline
The Following User Says Thank You to g25racer For This Useful Post:
tjeick (02-15-2013)
post #13 of (permalink) Old 02-15-2013, 08:03 AM Thread Starter
tjeick's Avatar
See that's what I thought. I've never worked with this shop before, this is pretty concerning that they're charging that much for them.
J.
tjeick is offline
post #14 of (permalink) Old 02-15-2013, 09:23 AM Thread Starter
tjeick's Avatar
I'm not sure what it's made of, but it does bolt straight on to the block, then connects to the torque struts, (which I've heard called dog-bones?) and the frame.
should I just go to any old parts store for those or is there somewhere special I should order from?
I need to get a good look in there to know what you mean about the coil pack, I think.
J.
tjeick is offline
post #15 of (permalink) Old 02-15-2013, 11:16 AM Thread Starter
tjeick's Avatar
The problem I'm having ia the same problem that this guy was having, with the mount on the block itself (or maybe the head).
http://www.impalaforums.com/automoti...2000-3-8l.html
J.
tjeick is offline
LinkBack to this Thread: http://www.impalaforums.com/chevy-impala-7th-gen-discussion/338763-new-motor-mounts.html
Untitled document This thread Refback 09-16-2014 07:38 PM
Motor mounts Smooth Operator Chevy Impala 6th Gen Discussion 45 09-23-2010 01:29 PM
What Motor Mounts are best? AlfredoSmith Chevy Impala 8th Gen Discussion 2 03-29-2010 11:46 AM
Bbc Motor Mounts LILTWIN 1st - 5th Gen Engine Performance 1 12-15-2009 11:10 AM
motor mounts 66CLEETUS Announcements 0 07-03-2008 06:51 PM
What are motor mounts.? missleggs Automotive Discussion 2 09-03-2007 08:42 PM
