replacing climate control panel bulbs - Chevy Impala Forums
post #1 of (permalink) Old 12-20-2012, 06:10 PM Thread Starter
jim1405's Avatar
Hi all,
I'm trying to replace the two burnt out bulbs (sliding temp adjusters) in my 2001 LS climate control panel. I've got the panel out and have removed the three tiny black screws on the edge of the backside and the four silver screws that are further in from the edge.
I had hoped the panel would then separate to get to the circuit board and bulbs but it's not working that way. Has anyone replaced these bulbs before?
Trying to figure out if I have to pull the control knobs off or what else to get this done and didn't want to force/break anything.
Greatly appreciate any advice you can offer!
Thanks!
Updated - I got the knobs off the two temp sliders and the fan speed but not the vent selector. It seems to be on really good.
jim1405 is offline
post #2 of (permalink) Old 12-20-2012, 07:14 PM
Storm Trooper Ralf
MixedImpala04's Avatar
I know you gotta solder on new bulbs. On naioa.com there is a right up on how to do it
MixedImpala04 is offline
post #3 of (permalink) Old 12-21-2012, 08:17 AM Thread Starter
jim1405's Avatar
2nd Update - Got the circuit board out. Was able to finally get the vent control off. It must have been loose at some point and the previous owner had put some type of glue on the shaft. There are 3 springs inside the backside part of the control that go between the electrical contact plate and shaft assembly that will fall out but it's clear where they need to go when reassembling. Hope this helps if you are going to try the same repair.
jim1405 is offline
climate control fullsize "DIY" Do it yourself/how to 1 02-12-2014 04:29 AM
dual climate control streetdreamz Chevy Impala 7th Gen Discussion 2 03-30-2012 06:04 AM
Can someone tell me if your climate control light does this also allen75 Mechanical and Electrical Problems 6 03-16-2011 08:20 AM
Climate Control Knobs RyanZ17 Chevy Impala 7th Gen Discussion 1 02-24-2011 03:04 PM
01 heater control light bulbs bowtievito Introductions & Welcome Forum 3 10-02-2010 05:02 PM
