Leaking Coolant...but where? - Chevy Impala Forums
post #1 of (permalink) Old 12-03-2012, 04:33 PM Thread Starter
child_of_fire's Avatar
Hey Guys,
You may have read my other thread about the heat blowing cold air....everyone said check the coolant which happened to be low. im on top of this stuff so i dont know how this got past me....
anyway, i was low again today while on the highway and this time so low that the engine temperature started rising dangerously....
i refilled the fluid, bled the system and noticed after reving the motor that fluid was spilling out above the belt just under the alternator (see picture).
any idea what this could be? is it a connector/connection? water pump? manifold? no ideas.. i dropped it off at the mechanic. my girlfriend drove behind me and it was a steady leak the whole trip. ...
child_of_fire is offline
post #2 of (permalink) Old 12-03-2012, 04:53 PM
auntjemima's Avatar
That's one of those leaky elbows the 3.8's have isn't it?
auntjemima is offline
post #3 of (permalink) Old 12-03-2012, 05:56 PM
Quoted: 34 Post(s)
Yes. Apparently, the otherwise reliable and popular 3.8 was notorious for these breaking and leaking.
I recently replaced them on my daughter's 1999 Lumina. That version of the 3.8 has two elbows, an upper and a lower. Earlier models only had the upper elbow.
FWIW, here's a good thread on the subject:
coolant bypass tube??? - Buick Forums
But I doubt it's needed since the OP is taking his car to a garage.
plano-doug is online now
post #4 of (permalink) Old 12-03-2012, 06:22 PM
Dorman makes aluminum elbows, also available from ZZP, they should be a lot more durable than those crappy plastic ones.
post #5 of (permalink) Old 12-03-2012, 07:26 PM Thread Starter
easy to do yourself?
post #6 of (permalink) Old 12-03-2012, 08:08 PM
00impala123's Avatar
Pretty easy. Remove the belt and alternator and you will have some room to work with
00impala123 is offline
post #7 of (permalink) Old 12-03-2012, 08:21 PM
Quoted: 34 Post(s)
In the thread I linked, there's an embedded video:
He does a couple things I don't like, but the vid will give you a pretty good overview of the job.
post #8 of (permalink) Old 12-04-2012, 02:13 PM Thread Starter
guys my mechanic says lot of things need to be moved to access this area...5 hours of labor....talking 450 dollars! is this right?
post #9 of (permalink) Old 12-04-2012, 02:30 PM
Quoted: 34 Post(s)
I did it in about 2 hours, and I'm far from a pro.
post #10 of (permalink) Old 12-04-2012, 03:28 PM
auntjemima's Avatar
thats ridiculous. do it yourself.
post #11 of (permalink) Old 12-04-2012, 04:13 PM Thread Starter
also can't find that aluminum elbow....any ideas?
post #12 of (permalink) Old 12-04-2012, 09:16 PM
The aluminum elbows are on both ZZP's website and W body store
And yeah. As stated, 5 hours labor is rediculous. Thats shop time for a LIM gasket job. I can do an entire LIM job in 3 hours. Coolant elbows alone in about an hour if I take my time
post #13 of (permalink) Old 12-05-2012, 04:56 AM
motorking's Avatar
coolant leaks
Hello,
I am the tech manager at Prestone Antifreeze.
Your vehicle has two plastic elbows right in the location you are talking about. They seem to rot out over time, I know we have replaced plenty of them in my shop. The parts are inexpensive but there is a couple hours labor involved. Make sure to refill with OAT coolant like Prestone DexCool or Prestone Extended Life coolant.
If you have any further questions, I can be reached directly at jay.buckley@framgrp.com
motorking is offline
post #14 of (permalink) Old 12-05-2012, 08:10 AM Thread Starter
thanks guys. all great help.
post #15 of (permalink) Old 12-05-2012, 10:00 PM Thread Starter
ended up being the o-rings that hold the elbow, not the elbow itself...
I think I have coolant leaking above front axel? Big B Chevy Impala 7th Gen Discussion 4 05-03-2012 05:44 AM
Leaking coolant,, stormbowling Chevy Impala 8th Gen Discussion 9 12-27-2011 02:20 PM
Coolant Leaking from somewhere luke_fairs Chevy Impala 7th Gen Discussion 11 12-23-2010 10:07 AM
2004 chevy impala overheating, leaking coolant,heater not working need help? Greg B Chevy Impala Discussion 2 04-27-2008 09:35 AM
2001 Chevrolet Impala (Common Problem) Oil Leaking into Coolant? Fr3EK Mechanical and Electrical Problems 1 03-03-2008 11:06 PM
