2003 impala 3800 misfire on cylinder 4 - Chevy Impala Forums
post #1 of (permalink) Old 11-17-2012, 09:07 AM Thread Starter
mjluard's Avatar
Exclamation 2003 impala 3800 misfire on cylinder 4
New to the forum so i would like to say thanks in advance for any and all help
my car is a 2003 impala with a 3800 . my cel is on with dtc p0300 i have a genesys scanner and watching the live data only cylinder 4 is missing .
now i have checked every thing i can think of and the miss is still there it only misses at idle if u bring the rpm upto roughly 1500 or more no miss.
things i have checked
1. new spark plugs (acdelco)
2. new wires (off name)
3. looked for vacume leaks with carb cleaner
4. swapped coils
5. swapped plugs
6.swapped wires
7. used a noid light to check injector circuit
8. swapped injectors
9.swapped ignition module with a known good one
10. car has a new cat. converter less tha month old
11. relearned crank position sensor
as u can see I could use a little help STUMPED
monday will be checking compression (although no abnormal engine noise can be heard) , also will recheck for a vacume leak with a smoke machine.
also as u can see i have access to most tools that could be needed
again any help would be greatly appreciated
mjluard is offline
post #2 of (permalink) Old 11-19-2012, 07:09 AM Thread Starter
mjluard's Avatar
compression test
cyl. 2,5,6 175psi
cyl. 1,3 170psi
cyl. 4 145 psi
well figured that was enough compression being that it is suppose to not be more than 70 % less than the highest cylinder witch would have to been 122.5 or less
y lack of compression figured could have been caused by the bad Cat. causing a build up of carbon on the valves
i ran two bottles of top engine cleaner through the car and wouldn't u know it miss gone
mjluard is offline
post #3 of (permalink) Old 11-19-2012, 08:08 AM
Back in Black
12ltz's Avatar
Good find glad you were able to get it fixed. I usually do top engine cleaner about every 60,000 miles but with the 2012 direct injection might change that 40,000.
_________________________
2012 Impala LTZ 72,000 miles
12ltz is offline
post #4 of (permalink) Old 11-19-2012, 11:47 AM
145 is NOT ok when the others are 170-175, looks like carbon on the valve seat was the issue though. Glad it's fixed!
2003 3.4L #3 cylinder misfire Firefighter Z Chevy Impala 7th Gen Discussion 13 04-13-2014 01:44 AM
Cylinder 1 misfire on 2005 Chevy Impala biglo Mechanical and Electrical Problems 2 03-27-2014 12:09 PM
3.4 problems p0481 and misfire cylinder #5 meandmycar Chevy Impala 7th Gen Discussion 3 05-12-2012 01:03 AM
1" lowering spring..Now feel vibration. #4 cylinder misfire and Reprogram pcm??? Weaver412 7th Gen Engine Performance 2 08-03-2010 06:38 AM
Misfire in cylinder 1 tt455 Chevy Impala 8th Gen Discussion 3 08-17-2009 08:22 PM
