gurgling water sound from behind dash - Chevy Impala Forums
post #1 of (permalink) Old 09-26-2012, 09:31 PM Thread Starter
child_of_fire's Avatar
hi guys,
weird noise coming from behind the dash sound near the driver's side. happens upon just starting up and taking off. sounds like water bubbles or water draining or something. been doing it for about3 years now since i purchased the 03 3800. no issues except for an occasional temperature gauge spike slightly above normal in hotter weather with traffic. figured it was air in the coolant line. tried bleeding the air out but still get the noise. whats the propper technique for bleeding air? i started the car and put the heat on high and opened the bleeder valve and let the car get hot and when mostly coolant was comming out i closed the bleeder.
child_of_fire is offline
post #2 of (permalink) Old 09-27-2012, 03:44 AM
auntjemima's Avatar
You are on the right path. It is low coolant. You are doing it correctly by opening the bleeder screws. Have you opened both?
auntjemima is offline
post #3 of (permalink) Old 09-27-2012, 05:37 AM
Joe
Joe's Avatar
I hear this from time to time also. I'll check it out.
** SOLD ** 2005 Impala - Base with a bunch of options / Debadged
1967 Camaro RS/SS L78 - Perpetual restoration project
2007 Trailblazer SS - Red Jewel
Joe is offline
post #4 of (permalink) Old 09-27-2012, 07:50 AM
00impala123's Avatar
3800 only has one bleeder screw, 3400 has two.
Just fill it and keep bleeding it, might take a while to get all the air out
00impala123 is offline
post #5 of (permalink) Old 09-27-2012, 08:23 AM
Joe
Joe's Avatar
I haven't looked yet, any tips on where said bleeder screws are? I have the 3.4l
Joe is offline
post #6 of (permalink) Old 09-27-2012, 08:31 AM
On the 3400 there is one on the t-stat housing, and one on the water pump inlet pipe.
post #7 of (permalink) Old 09-27-2012, 08:41 AM
jrd0304's Avatar
Make sure your radiator cap is good also, otherwise there won't be enough pressure in the system (~15 PSI) to bleed out all of the air. You'll bleed til the cows come home and wonder why you can't get all the air out. I knew mine was bad when the upper hose kept collapsing like snakeskin after the engine cooled off.
jrd0304 is offline
post #8 of (permalink) Old 09-27-2012, 02:25 PM Thread Starter
was pretty low on coolant. filled it at the radiator neck. cap looks good. believe its holding pressure. bled it again after i refilled. so far so good....
remember....
if it bleeds, we can kill it.
post #9 of (permalink) Old 09-27-2012, 02:51 PM
auntjemima's Avatar
When my water pump was leaking the only way I knew I was low or had an issue was the gurgling in my dash. I changed the pump and bled it a bit different than some with good results
post #10 of (permalink) Old 03-04-2014, 11:12 PM
Designated Driver
CinRed's Avatar
I have this sound.
It started approx. 2 months ago and it happens every time I start it up.
However, I haven't had ANY coolant leaks, temp spikes, or irregularities.
Is low coolant/air in line my issue as well?
TIA
"The weak are meat and the strong will eat."
CinRed is offline
post #11 of (permalink) Old 03-04-2014, 11:23 PM
zerialz's Avatar
Quoted: 10 Post(s)
yes. more than likely.
zerialz is offline
post #12 of (permalink) Old 03-10-2014, 01:35 PM Thread Starter
it came back. not sure why. annoying. but no ill effects.
post #13 of (permalink) Old 03-10-2014, 03:25 PM
zerialz's Avatar
Quoted: 10 Post(s)
Small coolant leak.. Think about this.. The cooling system is supposed to be filled to capacity and pressurized therefore there should be no way water can flow back and forth behind the dash. That fact you can hear it flow means there isn't enough coolant to fill the hoses. Have the system pressure tested.
zerialz is offline
post #14 of (permalink) Old 03-10-2014, 10:52 PM
g25racer's Avatar
I would check ur passenger side carpet guys. May have a leaking heater core.
Anywho If ur noise keeps coming back u either have a leak or u didn't get the system completely bled of air.
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
Thunderbolt Spun Cat
ZZP Alternator Power Cable
Wagner Thermoquiet Pads
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Dipped Rims and emblems
JBL GTO 6.5" and 6x9"
Sony MEX-GS600BT
Rockford P3 @ 500rms
g25racer is offline
post #15 of (permalink) Old 03-10-2014, 11:22 PM
zerialz's Avatar
Quoted: 10 Post(s)
g25 is on the money. You shouldn't hear splashing. Only time I did, the coolant was low or had air in the system after solving the low coolant issue.. Don't check the res to determine level. Check the rad.
zerialz is offline
LinkBack to this Thread: http://www.impalaforums.com/chevy-impala-7th-gen-discussion/331487-gurgling-water-sound-from-behind-dash.html
Water sound in dash? <- Find answers here! This thread Refback 01-17-2015 10:29 AM
Water sound in dash? This thread Refback 09-26-2014 06:49 AM
gurgling water sound from behind dash - Chevy Impala Forums This thread Refback 09-26-2012 10:52 PM
water?? lowminitruckin Chevy Impala 7th Gen Discussion 8 03-13-2011 08:59 AM
Water Sloshing Sound From Behind Radio ?? impala05 Automotive Discussion 3 07-05-2010 03:22 PM
1995 ss gurgling mrimpalaSS Automotive Discussion 4 08-22-2009 07:46 PM
How do I repair a water leak in dash of a 2002 CHevy Impala? maxhedr00m Chevy Impala Discussion 3 09-10-2008 03:42 AM
I have a 2004 chevy impala and has a water sloshing sound? Dave W Chevy Impala Discussion 3 09-30-2007 07:59 AM
