High beam problem. - Chevy Impala Forums
post #1 of (permalink) Old 08-16-2012, 07:34 PM Thread Starter
shufflefeel's Avatar
High beam problem.
I recently noticed the "high beam out" on the message center. Didn't think much about it. I just bought a new one. It didn't work when I replaced it. So I swapped drivers side and passenger side high beams to test it. It turns out the drivers side isn't getting power.
I've noticed also, the daytime running lights don't come on now. The full headlights come on instead. As if it's night.
I would assume there's some connection between the two issues. Anybody have any ideas?
2002 Impala 3800
Thanks
shufflefeel is offline
post #2 of (permalink) Old 08-16-2012, 07:40 PM
auntjemima's Avatar
Check your fuses
auntjemima is offline
post #3 of (permalink) Old 08-16-2012, 07:47 PM Thread Starter
Goes without saying. Like I said, it seems to be causing the headlights to come on instead of the daytime running lights.
post #4 of (permalink) Old 08-16-2012, 08:03 PM
josebmw's Avatar
check your relays.
josebmw is offline
post #5 of (permalink) Old 08-21-2012, 07:18 PM
DrewImpala's Avatar
BCM.. I had the same issue..
2000 Chevy Impala 3400
65mm Throttle Body
Port and Polish Intake Manifold
Custom K&N Cold Air Intake
MSD Ignition DIS-4 + MSD 8.5mm Wires
Autolite 104 Plugs
3" Downpipe and u-bend delete with Flowmaster muffler
180* Thermostat
Custom PCM Tuning
Optima Red Top Battery
Cross drilled and slotted rotors + F-Body calipers coming soon
4t65HD Transmission = Freshly rebuilt 12/2011
DrewImpala is offline
post #6 of (permalink) Old 08-22-2012, 10:36 PM Thread Starter
Turns out, condensation got in the headlight housing and corroded the main plug and socket. Easy fix once I tracked it down.
I need to find the high beam sensor for my 2002 chevy impala? shawn h199 Chevy Impala Discussion 1 06-02-2014 01:25 PM
High beam headlight aiming wscsuperfan Automotive Discussion 3 12-21-2011 09:45 AM
High beam switch questions krammit Chevy Impala 7th Gen Discussion 8 10-12-2011 09:18 PM
00 Chev Impala High Beam issue SonOfAnarchy Chevy Impala 7th Gen Discussion 0 04-23-2009 05:14 PM
Whelen Headlight High Beam Flasher will this work on my 1985 chevy impala? ryder99bst Chevy Impala Discussion 3 07-14-2008 11:12 AM
