Hello, i have been driveing my 2000 Impala LS at 4500-9000 feet in montana. i have put a K&N cold air intake, Overkill PCM, airaid Helix TBI spacer, mallory coils, JRP 10.4mm wires, poly mounts, Iridium Plugs, 180 thermostat, Intence raceing shift kit and filter change, 2.5" downpipe with high flow cat and u-bend deleate, and 2.5" cat back, new radiator, new fans and so on. i really enjoyed the power gains. then i drove to washington. i noticed when i got down closer to sea level my engine turned into a whole new monster. dispite the 100 degree heat and high humidity, the engine just had some extra snort when i stomped on the throttle.
Now, i read atricles that say "EFI outo adjusts to any condition so the engine will run perfect all the time no matter the elevation, weather, heat, ect." this is either not true or something is wrong with my car. any explenations? im kind of confused and dont really want to take it back to the mountains because it will feel slow again. unless there is a way to fix the problem. can the engine be tuned for higher elevations? Thanks! ![]() |
| Sponsored Links | |||
Advertisement | |||
#3 (permalink) |
The way your car runs will definitely change with elevation changes. You've got changes in Oxygen, pressures, temps, humidity, etc. You can have your car tuned to run differently in each situation, but ideally, you'd want to have something so that you can adjust the tuning depending on which situation you're driving in at any particular moment. I don't know a whole lot about the tuners for these Impalas and if there even is a tuner that will allow you to do that. Was your Overkill PCM done before or after you made all the other changes to your motor? If it was done before, I'd recommend you have it redone to optimize all the other changes you made. That may make it run better for you in your home use, but you'll probably still feel a change when you drive to other elevations. Who knows - it might make an even MORE noticeable improvement at the lower elevations then!!
__________________ Sawyer "Never drive faster than your guardian angel can fly!" |
#4 (permalink) |
![]() Join Date: Jan 2009
Yes EFI compensates for the changing altitude, but at higher altitude the air is thinner with less oxygen to burn fuel so the car makes less power. The EFI keeps the air fuel ratio correct and such but can't do anything about the lower oxygen content of the air.
TBI spacer is a waste. Mallory coils were a waste, the 10.4mm wires are just harder to route making them more prone to damage. Iridium plugs are to reduce gap errosion so they last longer, heck the car might have come with iridium I am not sure when they switched from platinum to iridium. But basically the stock ignitions are VERY good on modern vehicles to meet the LONG tuneup intervals and emissions standards. All you have done to the ignition didn't gain you power and probably didn't hurt but in all likelyhood it is going to need parts replaced sooner than if it had been OEM stuff. I am NOT a "stock parts only" guy but there are some stock parts that are very good. __________________ Dwayne 96 Caprice with AI 200cc package Best et 11.5 Best MPH 116 Just another taxi |
#6 (permalink) |
the reason i changed to the big wires is because all smaller wires inclueding the stock ones fell apart every time i took the boot off the spark plug. so i got rather angry and bought some that so far i havent had problems with, coils were next to first mod i did. i still have stock coils, so i can put those back on if needed.
so basicly im SOL unless i have 600 bucks to spend on a HP tuner? from w-body store or who ever has the best deal? |
#7 (permalink) | |
What amazed me is that the car lot didnt even check the plugs or anything |
#8 (permalink) |
The computer is already tuned to be able to cope with varying conditions, that is what the MAP and IAT sensors are for.
At lower altitude there is more pressure and therefore more oxygen available to the engine to burn fuel so it will make more power there, no amount of tuning will cause it to make equal power at high altitude. __________________ Dwayne 96 Caprice with AI 200cc package Best et 11.5 Best MPH 116 Just another taxi |
#9 (permalink) |
![]() Join Date: Mar 2009
Iridium was stock on all w-body cars. A tuner isn't going to help here, it's like Dwayne said, less oxygen is less available power, more oxygen is more available power, oxygen content in the air is directly proportional to altitude. The only thing that will make any difference at higher elevations would be if you rigged up some sort of oxygen injection system. Silicone in the spark plug boots will help keep them from sticking to the plugs.
#10 (permalink) | |
#11 (permalink) |
traditional "oxygen injection" system combine the oxygen with nitrogen think about it you will figure it out.
#13 (permalink) |
Nitrous oxide hits sold by Zex, NOS(Nitrous Oxide Systems), Harris Speed works and a LOT of others
NOS is a brand name but it has become popular slang much the way "Coke" is used to refer to cola __________________ Dwayne 96 Caprice with AI 200cc package Best et 11.5 Best MPH 116 Just another taxi |
#14 (permalink) |
Hey, you could justify the use of that TB spacer if you did it!
#15 (permalink) |
it has grooves in it. its suppost to give the incomeing air a vortec. idk if it is true or not. but to be honest i dont even think that it can seat nitrus. i might have to take it out and put a blank spacer in there. im not sure AirAid's spacer will hold up.
| Sponsored Links | |
Advertisement | |
| HEI Change out | B Town Cruiser | Automotive Discussion | 5 | 02-23-2012 06:24 PM |
| Chevrolet : Impala LS Reliable daily driver with higher miles, but great shape | RSS Bot | eBay Cars For Sale: Impala | 0 | 01-18-2012 04:30 PM |
| oil change | dwnsouthboi89 | Autocare and Maintenance | 17 | 10-24-2011 07:30 AM |
| stalling at higher speeds | mommyof2 | Mechanical and Electrical Problems | 9 | 12-04-2008 03:30 PM |
| can 20" rims or higher fit on a 92 cadillac fleetwood, even with the skirts?? | emilio s | Buick Roadmaster | 3 | 02-20-2008 11:40 AM |
