knocking noise - Chevy Impala Forums
Old 06-19-2012, 06:41 PM   #1 (permalink)
rosa6329's Avatar
knocking noise
Hi Guys, I have a 2004 Impala SS with 104k miles. Ive been hearing this knocking noise and have no idea where its coming from. Its not my octane because I use Super. This noise occurs when I am breaking, accelerating, turning, basically every which way possible. Could this be my suspension? sway bar? What do you think? Does anyone else have or had the same problem?
2004 Impala SS 3.8 Super Charged
Throttle Body Space
3.4 Pulley
K&N Cold Air Intake System
rosa6329 is offline   Reply With Quote
Old 06-20-2012, 09:49 AM   #2 (permalink)
csawyer's Avatar
If you're sure it's not in the motor, it sounds like a ball joint or shock mount issue. Ball joints will make a knocking sound when they're worn out, and they'll do it every time you turn or when the front end raises and lowers during acceleration/deceleration.
Sawyer
"Never drive faster than your guardian angel can fly!"
csawyer is offline   Reply With Quote
Old 12-20-2012, 04:43 PM   #3 (permalink)
breckimpalaforum's Avatar
On my 2003 the knocking comes from the intermediate steering shaft that has a long spline and u-joints at both ends. The spline binds up (torque lock) then releases causing a "knock" that can be felt in the steering wheel. Search on this and you will see a "fix" by squirting a lithium aerosol grease down the shaft at the base of the steering column by the floor.
breckimpalaforum is offline   Reply With Quote
knocking sound 03impala321 Automotive Discussion 7 06-11-2012 01:19 PM
Knocking while Idleing Stiglitz Chevy Caprice 2 12-03-2010 10:06 AM
2005 Impala Knocking Noise R2daMFin'B Autocare and Maintenance 7 10-26-2008 02:17 PM
Transmission makes knocking noise when it shifts back to first in my 93 Firebird formula93_350 Automotive Discussion 0 06-21-2008 05:57 AM
Knocking noise when I turn my 92' Buick Roadmaster on? rsgree Buick Roadmaster 0 02-20-2008 12:53 PM
