How long does it take to bleed air out of coolant system? - Chevy Impala Forums
post #1 of (permalink) Old 04-24-2012, 12:30 PM Thread Starter
unioncreek's Avatar
Well, I flushed the coolant. Even disconnected the heater core hoses and flushed that out. Had the front elevated about ten inches and bled the air out for 30 minutes and couldn't get it all out. So, I drove the front end up on a small hil so it was sitting at almost a 45 degree angle and bled the system another 20 minutes. The supply hose for the heater core is hot I can barely hang onto it, but the return line is cool. The heat coming out of the vent did get hot for about a minute and then cooled back down.
The coolant would come out of the bleeder valve only when I guess the thermostat would open up. I thought once it would build pressure it should blow all the time. I'm planning on driving it to see if the air will come out.
But, looking for suggestions.
Bobg
unioncreek is offline
post #2 of (permalink) Old 04-24-2012, 08:34 PM
Impalaforums.com
Stephen's Avatar
Seems like the core is still either clogged up or the air has not been bled out fully.
I have good success with just filling up the radiator first with the engine off and cool,
I then grab the radiator hose and give it a squeeze to force the coolant into the lines.
Then, once it is full, I start the car with the cap off, the coolant level will go down, I pour in enough to fill it and then put on the cap.
I then let it run until the temp gets up with the heat on high.
Then I open the bleeder valves until I see nothing but liquid coming out.
Sometimes it takes a few attempts but on my current 03 I only did 1 and it took about 45 minutes total.
Stephen is offline
post #3 of (permalink) Old 04-24-2012, 09:28 PM Thread Starter
unioncreek's Avatar
Stephen,
I finally got it bled tonight, but still have no heat. When I flushed the the radiator, I removed the hoses going to the heater core and flushed them out good. So, it is not plugged. Is there a solenoid or something that regulates the amount of coolant going through the heater core? If I run the heat on high and the fan on low it will get warm, but if I turn the fan too high it get cool real quick.
Bobg
post #4 of (permalink) Old 04-24-2012, 09:32 PM
Every 2nd Matters
Papa D's Avatar
Originally Posted by unioncreek View Post
Stephen,
Bobg
Still clogged. Run water through the Core in both directions. Then bleed air out again.
Jackass of all Trades
Tri-9 Defined: 1994, 1995 or 1996 B-Body.
1994 9c1- Goodbye Barricade.
Papa D is offline
post #5 of (permalink) Old 04-26-2012, 02:06 PM Thread Starter
unioncreek's Avatar
That's what I'm going to do this weekend, if it keeps raining. I only run water through it in the direction it normally flows. The more I think about this the more I think it is partially clogged. It seemed like it took quite a bit of water pressure to flush it the first time.
Bobg
post #6 of (permalink) Old 04-26-2012, 06:28 PM Thread Starter
unioncreek's Avatar
Raining tonight so I got a chance to work on the Impala. Pulled the heater core hoses and back flushed it first, the flushed the other way. Did this four times and finally got a bunch of crud to come out. Hooked the return line up, then used a funnel to fill the heater core until coolant started coming out of the block fitting. Started it up and within a few minutes had warm air then finally hot. Been driving it all winter without much heat, good thing it has heated seat.
Bobg
cant bleed air out of cooling system richp04impala Chevy Impala 7th Gen Discussion 26 03-14-2015 10:29 AM
96 SS coolant system... ssety Automotive Discussion 6 05-04-2011 04:52 PM
02 Chevy Impala: Low coolant light on, temp gauge acts funny, Plenty of coolant.? Nate P Mechanical and Electrical Problems 4 04-05-2011 11:51 AM
How to bleed breaks on 2005 Impala LS kill yor idols Autocare and Maintenance 0 10-05-2009 10:35 AM
How do I bleed air from power steering system in an '03 Impala .? sweetyebug3 Autocare and Maintenance 2 05-28-2008 11:50 AM
