oil pressure sensor question - Chevy Impala Forums
post #1 of (permalink) Old 03-15-2012, 01:52 PM Thread Starter
Lady McBeth's Avatar
Hi All,
I just want to get some input from anyone on my findings. I think the oil pressure sensor/sender is leaking on my 2003 3.4L.
Back story: about 2 weeks ago I was taking a road trip and I noticed white smoke following me. I pulled over, popped the hood and there was oil everywhere. I mean EVERYWHERE! I also noticed it squirting out the front of the engine. However, it was dusk so I was losing light quickly.
I towed the car home and that's where it sat until today. I started the car in daylight and noticed the oil streaming from behind the starter. I removed the starter and once it was out of the way, I saw the pressure sensor. So I figure it's the oil thing there has pressurized oil right there, so it has to be the culprit.
I just want some input. Also, if anyone knows what size socket or wrench fits, it would be great.
Thanks for any responses.
Lady McBeth is offline
post #2 of (permalink) Old 03-15-2012, 02:48 PM
The part is fairly cheap, I can't recall off hand the size, but its a big one, maybe 24mm? With the amount of oil loss you describe, thats probably what it is, but I would see if its just loose first, you never know.
post #3 of (permalink) Old 03-15-2012, 06:53 PM Thread Starter
Thanks for the reply Kingnutin. The socket is 1 1/16" - apparently there is an actual socket dedicated for this purpose and it has both 1" and 1 1/16" - the 3.4 uses the bigger size. It was $10 at Autozone.
Anyway, by the time I got back to my car tonight, it was dark so all I was able to do was remove the old one. Upon inspection, it is physically intact. The teflon tape appeared gone, but I suppose with almost 200,000 miles that should be a normal thing. I bought a replacement sender ($11 at Autozone). In the AM, I will resume working and see if this fixes the problem.
The Following 2 Users Say Thank You to Lady McBeth For This Useful Post:
jimbob0077 (06-11-2017)
post #4 of (permalink) Old 03-16-2012, 10:25 AM
Keep us posted.
post #5 of (permalink) Old 03-16-2012, 07:21 PM Thread Starter
Success! I installed it this morning and took it for a drive tonight. All appears well.
The only issue now is cleaning the engine and engine bay. It's not only unsightly, but it still smokes and stinks a bit from all the oil that got sprayed everywhere.
post #6 of (permalink) Old 03-16-2012, 07:29 PM
Divine Autosound
C.E.Divine's Avatar
To clean up the engine bay, warm the engine up a little, not ridiculously hot, just warm to the touch, and spray it down with this stuff called simple green. It is some good stuff. Let that soak for a bit, then hose it down with a garden hose. Just don't spray the computer or any ignition components for that matter. And to be safe, disconnect the negative battery terminal and wrap it in a plastic bag to keep it from shorting when you are spraying water.
Funny story about simple green, I use an old febreeze bottle that I refill from a gallon jug. In.high school, my mom.didn't know that I was doing it, and got it mixed up with her bottle of actual febreeze. She thought I would enjoy a fresh smelling bed one night, and sprayed my bed down....with an industrial degreaser. I woke up the next morning and asked her if she sprayed my bed with febreeze, and then informed her that it wasn't febreeze in the bottle. She thought it smelled good though. And at least it was non toxic.
C.E.Divine is offline
post #7 of (permalink) Old 03-16-2012, 07:33 PM Thread Starter
For those interested, here are a few shots I took of the part and tool.
post #8 of (permalink) Old 03-16-2012, 07:46 PM
Storm Trooper Ralf
MixedImpala04's Avatar
so the old one was allowing oil to pass by the threads and leak out?
MixedImpala04 is offline
post #9 of (permalink) Old 03-17-2012, 12:54 AM
Maybe through the center? The only part wet with oil is the plug.
post #10 of (permalink) Old 03-17-2012, 12:17 PM
Storm Trooper Ralf
yeah i see what your sayin, i wonder what caused it to do that? just wear?
post #11 of (permalink) Old 03-18-2012, 01:25 PM
No clue, but if it fixed it, great!
post #12 of (permalink) Old 03-18-2012, 01:31 PM Thread Starter
I fixed the car that day and my Internet decided to crap out that night. It seems everything in my life can't function simultaneously. LOL
Anyway, yeah, I am kind of stumped as to the mechanism of the leak. Because I really can't imagine the deterioration of the thread sealant to make oil jetisson the way it was. I figure something else inside the sensor had to break or something. I will check it out at my leisure. If I find anything, I will be sure to dig up this thread and post it. At any rate, the new sensor fixed the problem and so far (knock on wood) all is as perfect as it was a few weeks ago.
On a sidenote, there are 2 or 3 more photos that I'd like to post, but I can't seem to figure out how to get them to post as thumbnails. So if anyone can help before I can figure it out ... by all means let me know.
Thanks for the posts and views.
post #13 of (permalink) Old 03-18-2012, 01:33 PM Thread Starter
C.E. Divine ~
It's funny you mention the Simple Green because as much as my fiancee uses it on the engines that he builds, I somehow never thought of using it on my engine bay. Thank you. I will try that when I get around to cleaning it.
post #14 of (permalink) Old 07-18-2015, 01:18 PM
LA1
LA1's Avatar
yeah my oil pressure sensor on my 3.4L is leaking also, not quite as bad, I pulled off the connector and it had oil all over it., plus with a tech2 says there is a fault in the circuit. guess I will get another sensor.
LA1 is offline
LinkBack to this Thread: http://www.impalaforums.com/chevy-impala-7th-gen-discussion/316185-oil-pressure-sensor-question.html
how to change oil pressure sensor on 2007 impala | Smart Web Search This thread Refback 03-21-2014 12:59 PM
Tire pressure question Crime Scene Wheels and Tires 6 12-06-2011 10:59 PM
Barometric Pressure Sensor WoolyMammothCaprice454 Chevy Caprice 1 05-24-2011 08:51 PM
Oil pressure sensor/switch Bigbubble95 Chevy Impala 8th Gen Discussion 2 10-26-2010 09:55 AM
Tire air pressure sensor question engineerbll Wheels and Tires 2 09-06-2008 06:20 PM
Need Help locating fuel tank pressure sensor on 2003 Pontiac Vibe!!!!? caleb12312000 Automotive Discussion 1 09-09-2007 10:25 AM
