Blown head gasket - Page 2 - Chevy Impala Forums
Old 07-23-2012, 11:53 AM   #16 (permalink)
Head gasket is the last thing I would look at for a coolant leak, get it pressure tested first.
Old 07-25-2012, 03:35 PM   #17 (permalink)
cwa1104sab's Avatar
Here's a question, sorry if it sounds dumb.... When I torque the heads to 44lbs it says to go another 95 degrees. Question is are we looking at a circle with a 360 degree radius, so it's like another 1/4 turn ? That's what I'm thinking and I wanted to start getting everything back together this saturday.
Thanks for the help and confidence guys
much appreciated from this old man...lol
cwa1104sab is offline   Reply With Quote
Old 07-25-2012, 03:46 PM   #18 (permalink)
Impalaforums.com
Stephen's Avatar
yea, its gonna be slightly past a 1/4 turn since a 90 degree angle looks like an L then you just go ever so slightly past that.
I have a torque angle gauge but you cant print off something similar from a website and use that for accuracy if you want.
Past IOTM Winners http://www.impalaforums.com/iotm-win...m-winners.html
Stephen is offline   Reply With Quote
Old 07-25-2012, 04:36 PM   #19 (permalink)
5 degrees isn't going to make much difference either way, just do your best to get 90 degrees or slightly past.
Old 07-25-2012, 08:00 PM   #20 (permalink)
cwa1104sab's Avatar
Guys I can't thank you all enough...Saturday is the day to start it all going back together and remarcably the only thing I'm worried about is the 90 degree turn thing(but you solved that) and also where to put the head bolts since some are longer than others and where to put the ones that are "taller" I'm hoping that answer is in the haynes book I bought. Aslo should I put anything on the bolts ?
Old 07-26-2012, 10:28 AM   #21 (permalink)
Stephen should be able to answer the question about whether or not to coat the threads, I haven't done one of these yet so I'm not sure. But for the different bolt lengths, trust me, it will be obvious once you take the old bolts out.
Old 07-26-2012, 01:18 PM   #22 (permalink)
Impalaforums.com
Stephen's Avatar
Clean the inside of the head bolt holes out before installing the new head bolts. The book says to chase the threads using a tap, I did not do that. I used a Q-tips and cleaned them out since they were not very dirty or anything.
Apply thread sealant to the threads before putting them in. I used permatex High Temperature Thread Sealant. part# 59214
Get you some PB-Blaster or some good penetrating oil and soak the exhaust studs and bolts good, possibly the night before, or at least give them a few hours to soak.
You can follow the tightening sequence and just mark the bolts as you take them out with the corresponding number. Then take the new head bolts and match them up.
You can use this thread along with your haynes book for assistance
http://www.impalaforums.com/diy-do-i...s-3400sfi.html
(Remember, the picture is the TIGHTENING sequence, so you reverse the order for removal
or this picture-
Old 07-26-2012, 06:44 PM   #23 (permalink)
cwa1104sab's Avatar
Got it, thanks !
Old 07-30-2012, 05:29 PM   #24 (permalink)
cwa1104sab's Avatar
Going back together nicely with no major mishaps so far, I printed out your steps and as I do them I'm checking everything off as I go. I'm up to putting the plenum on. Actually getting a great deal of satisfaction out of this...
Old 07-31-2012, 01:39 PM   #25 (permalink)
Nothing quite like it is there? I wish more people here would realize just how easy it is...
Old 07-31-2012, 06:18 PM   #26 (permalink)
Impalaforums.com
Stephen's Avatar
Yep,
Let me know how everything turns out.
Old 08-03-2012, 09:05 AM   #27 (permalink)
cwa1104sab's Avatar
Guys I just wanted to publicly thanks everyone who helped me with my heads on my 04 3.4...It's up and running. Without your input, even though I've done them before 30 years ago, I never wouldve tried it. Stephen's walk thru was printed off and followed step by step and at the end it started on the first crank. The oily smell of new heads is almost burned off and I'll be driving it around the next few weeks watching for leaks and checking the gauges.
Again thanks to all who helped, especially Stephen and Kingnutin. My wife is amazed that perfect strangers would take the time to help another stranger do such this job.
Sab
Old 08-03-2012, 11:02 AM   #28 (permalink)
We're just doing what we can to make the world a better place, treat others as you would have them treat you.
LinkBack to this Thread: http://www.impalaforums.com/chevy-impala-7th-gen-discussion/313377-blown-head-gasket.html
Chevy Impala Forums This thread Refback 07-26-2012 08:17 PM
Blown head gasket - Chevy Impala Forums : 2011 Impala Forum This thread Refback 02-20-2012 09:40 PM
Blown head gasket - Chevy Impala Forums : 2011 Impala Forum This thread Refback 02-20-2012 09:57 AM
new updated pics of 03 head gasket fix Stephen Automotive Discussion 0 09-28-2011 09:50 PM
pics of head gasket replacement Stephen Automotive Discussion 0 09-17-2011 06:42 PM
head gasket job MXZ1983 Chevy Impala 7th Gen Discussion 0 04-01-2011 11:35 AM
Blown Head Gasket?? drab84 Mechanical and Electrical Problems 7 10-27-2009 09:31 AM
92 chevy s10 blazer-blown head gasket? stikclik Automotive Discussion 3 09-08-2007 05:17 PM
