2005 3.4 impala code p0300 - Chevy Impala Forums
post #1 of (permalink) Old 08-07-2011, 09:53 PM Thread Starter
aztecs2006's Avatar
I went to turn on car this morning and it made a weird noise at first then stopped. Check engine light came on for first time ever. P0300 multiple cylinder misfire detected. Can anyone tell me how to find the problem. Is it bad to drive in the mean time. i posted a another thread a while mentioning my air pressure was 40 kpa. Someone told me that wasnt normal. I was reading about how a the intake might be leaking air. Can someone confirm.
aztecs2006 is offline
post #2 of (permalink) Old 08-07-2011, 10:08 PM Thread Starter
aztecs2006's Avatar
A few of you might know Ive also been having tranny problems. My tranny lags to shift into 2nd. I took my car for a test drive, it makes sort of a rattling noise when I accelerate.
post #3 of (permalink) Old 08-07-2011, 10:12 PM
The rattling noise could be spark knock, I'm not sure, but that may be the cause of the code. I would be interested to see the live data readings on the spark advance.
post #4 of (permalink) Old 08-07-2011, 10:20 PM Thread Starter
aztecs2006's Avatar
How do I check those reading, I have obd-2 scan tool with a pcmscan program. I have never changed my spark plug wires, only spark plugs. Car has 125,000 miles.
post #5 of (permalink) Old 08-07-2011, 10:23 PM Thread Starter
aztecs2006's Avatar
Actually I just found it on my program spark advance(ignition timing advance #1 cylinder
post #6 of (permalink) Old 08-07-2011, 10:27 PM Thread Starter
aztecs2006's Avatar
Can I pm you kingnutin and send you a screen shot of the readings
post #7 of (permalink) Old 08-07-2011, 10:37 PM Thread Starter
aztecs2006's Avatar
Here are the readings
post #8 of (permalink) Old 08-07-2011, 11:09 PM Thread Starter
aztecs2006's Avatar
I reset the code, If it is a cylinder misfiring how long until the check engine comes back on.
post #9 of (permalink) Old 08-08-2011, 12:10 AM Thread Starter
aztecs2006's Avatar
Also if it was the spark knocking wouldnt it knock while idling, it only makes that rattling sound when im accelerating while driving.
post #10 of (permalink) Old 08-08-2011, 11:54 AM
If you've never changed the wires, do that first, it needs to be done anyway. That data sheet doesn't show anything on the advance, I'm a bit confused by that. Just see how it does after the wires are done, we'll go from there.
post #11 of (permalink) Old 08-08-2011, 06:58 PM Thread Starter
aztecs2006's Avatar
Ima go ahead and replace both spark plugs and wires sometime this week. Any idea how to check if a have vacuum leak and if my coil packs are still good. Want to change it while im add it.
post #12 of (permalink) Old 08-09-2011, 12:22 PM
The coil packs you can check the resistance of each one, for vacuum leaks you need a spray can of carb cleaner, brake cleaner, wd40, or something of the sort. With the engine running, spray it on all vacuum lines and fittings, one at a time, and see if the engine speed changes. If there is a change, you have a leak in that spot.
post #13 of (permalink) Old 08-10-2011, 01:33 PM Thread Starter
aztecs2006's Avatar
Got another problem, been having transmission problems for the past months. Before my car would lag before going into second. Now When I first accelerate my car lags and it wont go into first feels likes its pulling itself. Is that the transmission that finally shot itself.
post #14 of (permalink) Old 08-11-2011, 11:49 AM
You probably just need to replace the solenoids.
Chevrolet : Impala IMPALA SS 1996 IMPALA SS- AUTHENTIC WX3 CODE IN A DGGM COLOR CODE RSS Bot eBay Cars For Sale: Impala 0 03-15-2011 09:30 PM
EST Code 42 monroe Automotive Discussion 5 12-13-2010 10:22 AM
2005 hw mm#5 8 1965 chevy impala c#2005-105 fte RSS Bot Impala Diecast Toys Cars on eBay 0 06-28-2010 11:50 AM
MAF Code dbede Automotive Discussion 2 03-14-2010 01:02 AM
what would be better a 2005 chevy impala or a 2005 suzuki forenza? Slik 420 Chevy Impala Discussion 0 03-24-2008 01:26 PM
