Bad EGR valve? 2003 Impala 3.4L - Chevy Impala Forums
post #1 of (permalink) Old 07-04-2011, 10:56 AM Thread Starter
JustinMP's Avatar
Hey guys,
After taking care of all of the major problems with my Impala (LIMS for example), I've started to work on the smaller problems (rust, slight rough idle, etc).
I recently purchased the OBDPros USB scan tool. I decided on this one mainly because of the double buffering and firmware upgrade capability.. so I can keep it for a long time and still use it with newer vehicles.
My car has had this.. "whistling" sound when idling, it slightly changes with RPM, but I can't hear it when driving - it's probably drowned out. I also can't seem to hear it from the engine bay, which may also be because it'd being drowned out. I know there's a TSB on this sound, which describes how it is likely due to porosity in throttle body. I don't think porosity in the throttle body would cause what I found out below:
So... arrive the scan tool. At idle, my Short Term Fuel Trim ranges from 0-3, and my Long Term Fuel Trim stays around -14.1. Intake Manifold Absolute Pressure stays around 10.3 inHg, MAF stays around 0.54 lb/min, Ignition Timing Advance for cylinder #1 stays between 19-20. Idle RPM ranges from 650-740. When I say my car has a rough idle, I don't mean the engine sounds rough or the car shakes badly. But, the car shakes every 2 seconds. It's hard to describe but doesn't seem normal. Based on what I've been reading and the scan data I have.. it seems like I have a vacuum leak (MAP at 10.3 idle?), and the car is running rich ((Well, before being corrected by the FTs) LTFT at idle being -14) but I could be wrong.
Here is some data I graphed of a short drive:
I just have a feeling it could be the EGR valve based on what I've read.. but I was wondering if anyone here had any ideas. LIMS have already been changed and this whistling/"rough idle" was occurring before that.
Thanks and sorry if something like this has already been posted that I missed .
JustinMP is offline
post #2 of (permalink) Old 07-07-2011, 08:09 PM Thread Starter
JustinMP's Avatar
I hate to bump.. but does anyone think I have a vacuum leak of some kind, and if so should I worry about it/any ideas where it might be?
JustinMP is offline
post #3 of (permalink) Old 07-08-2011, 05:41 AM
AlfredoSmith's Avatar
I was going to say it sounds like a possible vacuum leak... 9 times out of 10 i think the EGR would throw a code?
SPACE FOR RENT
AlfredoSmith is offline
post #4 of (permalink) Old 07-08-2011, 12:31 PM
Moderator
04DetroitLS's Avatar
map is low, should be around 16 iirc
MAF increase w/ throttle right?
04DetroitLS is offline
post #5 of (permalink) Old 07-08-2011, 05:08 PM Thread Starter
JustinMP's Avatar
MAF does increase with throttle.
JustinMP is offline
post #6 of (permalink) Old 07-12-2011, 09:55 PM Thread Starter
JustinMP's Avatar
So any ideas for what I should check? Maybe I could record the "whistling" sound I'm talking about..
JustinMP is offline
EGR valve is bad salvador85 Chevy Impala 8th Gen Discussion 8 12-29-2015 11:34 AM
egr valve houimpala96 Chevy Impala 6th Gen Discussion 0 02-21-2011 07:06 AM
IAC Valve texaschevyryder Chevy Caprice 5 04-30-2010 05:29 PM
EGR valve griffenspade Chevy Caprice 3 02-12-2010 07:17 PM
Which of these cars would be better 2003 nissan altima, 2003 toyota camry, 2003 camille b Chevy Impala Discussion 8 05-14-2008 10:30 AM
