Problems starting with cruise control - Chevy Impala Forums
Old 06-29-2011, 04:20 AM   #1 (permalink)
Boosted '04's Avatar
Angry Problems starting with cruise control
I'm starting to notice the cruise control disengaging for no apparent reason. Anyone have this problem too?
I think I'm going to start searching for a new cruise control module for the SS this weekend. Anyone have a guess on replacement cost? I'm thinking $100 - $150 should cover it.
04 Impala SS
RX330:TSX-R * Morimoto 5Fives * Morimoto 5K Bulbs * Iris Shrouds
N. White LED Plate Lights
Coming Next Year : OEM Style LED Tail Lights
Boosted '04 is offline   Reply With Quote
Old 06-29-2011, 05:25 AM   #2 (permalink)
AlfredoSmith's Avatar
Might want to scan for codes.. I think a faulty cruise control would trip a BCM code or something.
SPACE FOR RENT
AlfredoSmith is offline   Reply With Quote
Old 06-29-2011, 03:24 PM   #3 (permalink)
I can also look into this for you. In order to more research I will need the VIN for the vehicle. Please feel free to contact me via private message as well. Thank you.
Tricia, GM Customer Service.
ChevroletCustomerService is offline   Reply With Quote
Old 06-29-2011, 05:16 PM   #4 (permalink)
synysterjoe's Avatar
check your brake switch behind your brake pedal. a loose wire that intermittenly makes ground could cause your problem. its the cheapest thing to check first.
2000 ls blacked out is how this guy rolls
synysterjoe is offline   Reply With Quote
Car starting problems mike27 Chevy Impala 7th Gen Discussion 30 07-04-2011 12:32 PM
cruise control or what ? lt1 MUNSTER Chevy Caprice 3 08-08-2010 08:16 PM
Starting Problems knunruh Automotive Discussion 2 04-02-2010 03:47 PM
Starting problems luke_fairs Chevy Impala Discussion 1 09-23-2008 10:20 PM
2001 Impala Starting Problems? lukefairs87 Mechanical and Electrical Problems 1 11-11-2007 06:11 PM
