Over voltage problem - Chevy Impala Forums
Old 04-23-2011, 12:08 PM   #1 (permalink)
loonysalmon's Avatar
Send a message via Skype™ to loonysalmon
Hey all, I had a bit of a problem with my 2002 impala not starting so I decided to get a jump as I figured the battery had drained out after sitting for the past month. I got a jump and was checking my voltage across the battery terminals and was surprised when I saw that it was showing +23.2V.
So right then I disconnected the battery and went to take the connectors off when the positive terminal started pulling off (mind you these are sidepost batteries). I cleaned out the inside of the positive terminal because there was a tonnnnn of corrosion but after cleaning realized that the battery was actually leaking. So of course I got another battery and checked voltage across terminals before putting it in and it was sitting at 12.5. I tossed it in the car and started it up to find out that afterwards it was putting out 19 volts again.
Largely this leads me to believe that there is a problem with a voltage regulator, however I have no idea what to look for or replace, other than knowing that it is related to the alternator.
Can you guys help me diagnose what the actual problem is? I have only today to fix this problem because I have a final exam at school on Tuesday and need monday to drive up there. Please help me with this ASAP. I've been a member of the CB7tuner forums for a number of years and they were always helpful to people; I am sure this family is the same!
-Tom
2002 Impala 3400
loonysalmon is offline   Reply With Quote
Odd Problem kingnutin 1st - 5th Gen Engine Performance 3 03-19-2011 10:58 AM
Charging voltage Verne Mechanical and Electrical Problems 4 03-10-2011 12:11 PM
Has anybody had this problem before? banglinj Automotive Discussion 11 07-28-2009 12:25 AM
hello and a problem molbly Chevy Impala 7th Gen Discussion 7 03-13-2009 06:29 PM
HELP!!!Very Odd Problem With My 96 LT-1 arosado Automotive Discussion 1 11-06-2008 04:19 PM
