Security Light - Chevy Impala Forums
Old 04-19-2011, 07:53 AM   #1 (permalink)
Joe-Bananas's Avatar
Security Light
I just got my car out the shop yesterday(not a GM shop), and I noticed after driving it a few miles my security light came on. I didn't think nothing of it, I figured it would disappear after I turned the car off and turned it back on. I turned it off and turned it back on when I got home and it said "low fuel", the security light came back on, a red light came on not sure which one. Then I turned the car back off, started it back up and everything was fine. I called a GM dealer and they said they'll charge $91 just to perform a diagnostic. Now here's my question, could it be possible the shop I went to disrupted a sensor and it's causing the light to come on? or is it that I have to have something major replaced?
Joe-Bananas is offline   Reply With Quote
Old 04-19-2011, 08:29 AM   #2 (permalink)
TSS
TSS's Avatar
If it is fine now - forget about it. If battery gets too low wierd things can happen - often happens while car is being worked on - they leave the door open, lights on etc. Also, the year of your car may assist others in helping you.
2009 Impala SS (sold 3/2012);
2010 Buick Enclave CXL;
2010 Lincoln MKS AWD Twin Turbo, Livernois Motor Sports tuned, Airaid CAI, 0-60 in 4.47 seconds
TSS is offline   Reply With Quote
Old 04-19-2011, 10:43 AM   #3 (permalink)
It's a 01. I googled the problem and seen other people with similar problems. Some people were saying it could be the ignition cylinder, some even said something as simple as a worn out key. My thing is, I'm just trying to avoid the dealership and spend $91 just for them to tell me something and nothing was worked on, you know? But right now? It's tricky. Sometimes it would start right up, other times I would have to wait a while then try again and it starts up with no problem. I'm just hoping I can avoid a visit to the dealer with a simple home solution or even a cheap solution by getting a key in better shape
Old 04-19-2011, 10:55 AM   #4 (permalink)
thacarter546's Avatar
^My solution is a simple one. Go to a good reputable stereo/security shop in your area. Have them install a passlock bypass unit, and if you want a basic alarm.
thacarter546 is offline   Reply With Quote
Old 04-19-2011, 12:34 PM   #5 (permalink)
You can find more information on page 2-28 of your owner’s manual. Your vehicle is equipped with the Passlock theft-deterrent system. Passlock is a passive theft-deterrent system. Passlock enables fuel if the ignition lock cylinder is turned with a valid key. If a correct key is not used or the ignition lock cylinder is tampered with, fuel is disabled and the engine will not start. During normal operation, the SECURITY message will be displayed after the key is turned to the ON ignition position. See “Message Center, Security” in the Index. If the engine stalls and the SECURITY message flashes, wait until the light stops flashing before trying to restart the engine. If the engine is running and the SECURITY message comes on, you will be able to restart the engine if you turn the engine off. However, your Passlock system is not working properly and must be serviced by your dealer. Your vehicle is not protected by Passlock at this time. You may also want to check the fuse (see “Fuses and Circuit Breakers” in the Index). See your dealer for service. In an emergency, contact Chevrolet Roadside Assistance. See “Roadside Assistance” in the Index for more information. I can also look into this further for you with the VIN from your vehicle. Please feel free to contact me either in the thread of via private message. Thank you.
Tricia, GM Customer Service.
ChevroletCustomerService is offline   Reply With Quote
Old 04-19-2011, 01:32 PM   #6 (permalink)
I'm going to try that. It might save me some money
Old 04-19-2011, 01:42 PM   #7 (permalink)
^Or disable it and get a security system that works lol.
Old 04-19-2011, 01:45 PM   #8 (permalink)
TSS
TSS's Avatar
Good suggestion ^^
Old 04-19-2011, 05:16 PM   #9 (permalink)
Lol I was talking to a friend of mine and he told me to do the same thing. But the question is, how to you disable the passlock? I thought that was like computer generated or something
Security Light WHBFD521 Chevy Impala 7th Gen Discussion 6 12-09-2012 08:58 AM
2004 Impala LS Security light joeymvanostrand Audio, Video, and Electronics 1 09-17-2010 05:29 PM
2001 Chevy Impala Security Light? Maurcus D Chevy Impala Discussion 1 12-14-2007 05:37 PM
99 pontiac grand am security light comes on car wont start what to do? buggy Automotive Discussion 0 09-09-2007 08:23 AM
while driving my 2000 chevrolet impala my security light comes on? raymann Mechanical and Electrical Problems 5 09-03-2007 12:16 AM
