Keep blowing fuse for back-up/reverse lights - Chevy Impala Forums
post #1 of (permalink) Old 12-29-2010, 08:15 PM Thread Starter
schwebby's Avatar
I noticed the other day when I pushed the remote lock that the back-up lights did not light up. I checked the fuse (10A) and it was blown - I replaced it and tried it again - the backup light flashed for a second when I pushed "lock" and then the fuse was blown again. Has anyone else had an issue with this? I noticed this 2 days after I was playing around with a loose connection on the auto dimming rear view mirror - could there be any coincidence between the two? Thanks
2005 Impala
schwebby is offline
post #2 of (permalink) Old 12-30-2010, 06:31 AM Thread Starter
schwebby's Avatar
Does anyone know if there a reverse light switch on the transmission? Could this possibly be the problem?
2005 Impala
schwebby is offline
post #3 of (permalink) Old 12-30-2010, 09:34 AM
Quoted: 15 Post(s)
Not sure, but maybe a bad electrical harness or something? In regards to the fuse blowing, maybe you're shorting it for some reason. Have you switched the bulbs lately?
Shop for Impala Parts:
www.basilonestopshop.com
donmateo is offline
post #4 of (permalink) Old 12-30-2010, 09:34 PM
dyslexic doggie's Avatar
okay i can tell you with some degree of confidence that if your blowing fuses that quick then yes you have a short., do not put a bigger fuse in, this will cause some nasty other problems.
you can check the wires with a meter goin backwards from the light receptacle to where they meet a harness somewhere check all places it connects with other harnesses.
at work we trip breakers and blow fuses from a loose plugs arcing.
dance dance everyone!....ok maybe not you.
dyslexic doggie is offline
post #5 of (permalink) Old 12-31-2010, 04:53 PM
TSS
TSS's Avatar
Quoted: 49 Post(s)
Don't ask me how I know this or why I had to buy a 25 gross pack of 10 amp fuses today when installing my HIDs (I swear, its the truth), but make sure you did not plug the harness in upside down in the tail light. Somehow, I manage to do that on one headlight. It actually fit upside down (so it was reversed). Turned a one hour job into three hour job.
2009 Impala SS (sold 3/2012);
2014 Impala Limited LTZ
2010 Buick Enclave CXL;
TSS is offline
post #6 of (permalink) Old 12-31-2010, 11:48 PM
diagger's Avatar
The light green wire inthe rear view mirror harness is connected to the backup lamp relay which is powered by the b/u lamp fuse 10amp. I would discinnect the rear view inside rear view mirror and see if you short goes away. Before you do that, try to inpect both side of that connnector to soo if maybe there's a frayed wire in that area that is maybe shorting out.
Love the Lord. Love my family. Love America. Happy to help.
diagger is offline
post #7 of (permalink) Old 12-31-2010, 11:54 PM
diagger's Avatar
As far as the reverse switch. The circuit that tells the powertrain control module that your in reverse position which then tells the body control module that it's in reverse, is not powered by ther back-up lamp fuse. Not your problem here.
diagger is offline
post #8 of (permalink) Old 01-01-2011, 07:53 AM Thread Starter
schwebby's Avatar
thanks a bunch diagger - I was thinking there had to be a connection - too much of a coincidence.
I will try disconnecting and see if it goes away - when you say to inspect the connector - are you talking about the rear view mirror connector - or a backup light connector?
thanks again
2005 Impala
schwebby is offline
post #9 of (permalink) Old 01-01-2011, 08:01 AM
diagger's Avatar
The connector at the rear view mirror harness.
diagger is offline
How do you change reverse lights in a 2004 Chevy Impala? hova6662002 Chevy Impala Discussion 1 05-02-2008 06:33 PM
i have a 2002 impala i want to cover the back lights? my_juicy_snatch Chevy Impala Discussion 5 03-10-2008 05:04 PM
My truck won't go in reverse!!!? Jaileen Automotive Discussion 0 09-17-2007 01:15 AM
How do i get the back speaker panel to come up so i can change my back speakers in urchefsfavoritechef Audio, Video, and Electronics 1 09-02-2007 05:57 PM
03 impala and my back tire is pushed back alittle i went to a shop they said i Shawn S Mechanical and Electrical Problems 2 09-02-2007 01:10 AM
