mileage on cluster - Chevy Impala Forums
Old 10-19-2010, 09:25 AM   #1 (permalink)
brigoyanks's Avatar
mileage on cluster
so i got a new cluster because my old one broke and i wanted the upgraded one with all the extra gauges and now my mileage is off..by like 120,000 miles....how do i fix this and make it say my correct mileage? any suggestions
2004 impala 3.4l with a Monte Carlo SS cluster swap
brigoyanks is offline   Reply With Quote
Old 10-20-2010, 02:09 PM   #2 (permalink)
brigoyanks's Avatar
does anyone think i can get it done at the dealership?
Old 10-20-2010, 03:22 PM   #3 (permalink)
Resident Post-Whore
Maybe, give em a call and check it out and see. The worst they'll say is no.
www.basilonestopshop.com
donmateo is online now   Reply With Quote
Old 10-20-2010, 07:52 PM   #4 (permalink)
brigoyanks's Avatar
figured it out.. found a guy who does them..he also does the LED backlighting too...turns out he lives in the town next to me....lol small world BBEngineering
Old 10-20-2010, 07:59 PM   #5 (permalink)
Resident Post-Whore
Yeah, he's well known, I don't recommend him personally, but I've got beef. Heard he does good work, though.
Old 10-25-2010, 04:52 PM   #6 (permalink)
Scoobywic's Avatar
Smile Question about SS speedometers
I literally joined this forum so that I could ask you this because you are the only person (apparently, I did some searching through this site but just couldn't find just what I was looking for) that has posted much about the instrument clusters on the 7th gen Impalas. I was wondering if the instrument clusters from the SS are "plug and play" with the base model Impala... I have a base model (for now) and I plan to do a lot of upgrading on it and one of the first things I would like to do is to get a tachometer but I want it to look as close to stock as possible, I'm not a big fan of the 7-inch tach ghetto mounted on my dash that obviously didn't come with the car so I decided on the SS cluster. I just want to verify that it will be a somewhat easy install. (plug and play would be AWESOME)
P.S. I plan on making a thread here for my car, I enjoy sharing my work with others even though I'm definitely a newbie.
Thank you,
Scoobywic
Scoobywic is offline   Reply With Quote
Old 10-25-2010, 05:26 PM   #7 (permalink)
Resident Post-Whore
^^Thanks for joining! Please introduce yourself in the proper forum sub-section.
To answer: Yes, it IS plug and play, BUT your oil gauge will NOT work. You could go for an A-Pillar gauge system, as well. Can't wait for pics!
Old 10-25-2010, 05:57 PM   #8 (permalink)
Scoobywic's Avatar
Smile Thanks!
Okay cool! That is the only gauge that won't work correct? The tach, speed, gas, and temp will? I will upload as soon as I get home haha, working late tonight.
Old 10-25-2010, 07:40 PM   #9 (permalink)
Resident Post-Whore
IIRC, only the oil doesn't work. If you can, find a LS Sport gauge, then I think all gauges will work via plug n play.
And sounds good! Have with the fun late night! ;)
Old 10-25-2010, 09:20 PM   #10 (permalink)
Scoobywic's Avatar
Haha, I got the pictures and a whole thread up already. They are in this section. Does the LS "sport" gauge come in all LS's? Or only certain ones? Also does this work for 2000 - 05 or is it only for 2002 since thats the year mine is. I've read that theres a difference in pre-2003 Impalas even though they are still 7th gen, any idea about that?
Old 10-26-2010, 05:13 AM   #11 (permalink)
Moderator
wanderson75's Avatar
I've you have a 3.4L engine, the oil press on the LS and SS clusters will not work. If you have a 3.8L engine (which came in some base models) it will work fine.
And BBEngineer does awesome work and is a great guy. Donmateo just got on his bad side. :-P
–adjective
wanderson75 is offline   Reply With Quote
Old 10-26-2010, 02:43 PM   #12 (permalink)
Resident Post-Whore
^Tool...... :P
FYI, I didn't even do anything, he just wanted to ban me. Ask, TSS, (not to drag him into this) but he knows. It was all about a stupid joke.
And, PS, I've you have? Come on, Wanderson, you're better than that!
The gauge came in LS Sports and I think only 2000s were the issue.
Old 10-26-2010, 04:26 PM   #13 (permalink)
Moderator
Rewind that sentence...what?
And what issue with the 2000s?
–adjective
Old 10-26-2010, 05:01 PM   #14 (permalink)
Resident Post-Whore
The plug issue or whatever it was. Something about how only 2000 gauges worked with 2000s.
Old 10-27-2010, 01:13 AM   #15 (permalink)
brigoyanks's Avatar
i just got a 2000 gauge for my 2004 all the gauges work except the oil cause i have a 3.4l...BBEngineer is programing right now for me
2004 Impala 3400SFI LA1
Performance Mods: Custom k&n FWI, Thrush Weld Dual Mufflers, Dual 3" T304 SS Tips, 180° t-stat, ZZP Downpipe, High-Flow Magnaflow Cat, High Flow Fuel Filter, Adjustable Fuel Pressure Regulator, ZZP Poly Dogbone Mounts, Overkill PCM, TCE 65mm TB, WOT-Tech Upper Intake Manifold, EGR Delete, Poly Trans Mount
PLEASE VOTE FOR ITOM
http://www.impalaforums.com/iotm-sub...ns-and-voting/
Z28 Cluster Conversion mmd8x28 Chevy Caprice 8 10-30-2010 02:58 PM
Cluster gone BAD iceship Chevy Impala 6th Gen Discussion 4 09-08-2010 11:34 PM
Speed cluster Smooth Operator Chevy Impala 6th Gen Discussion 7 05-02-2010 02:30 PM
gauge cluster ?s Natedogg713 Chevy Impala 7th Gen Discussion 32 02-07-2010 02:13 PM
Cluster bulbs scirks Chevy Impala 7th Gen Discussion 2 01-10-2009 02:39 PM
