Replacing the oil pan on 3.8L... difficulty?
The oil pan on my 2002 with 3.8L is getting thin from rust.
I read up on the service procedure. What looked like it should be pretty straightforward requires a external engine holder and removing some / all of the lower motor mounts and some of the accessory drive. Anyone that's done this procedure that can comment on what needs to come out to do this job? Workarounds? Or is it pretty much as listed above? I've pulled motor mounts for service by supporting the oil pan on a jack; obviously that's not possible here. |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) | |
Moderator
![]() Join Date: Apr 2009
You'll need a cherry picker to support the engine while you change it out. The passenger's side mount will need to be removed.
__________________ ![]() Quote:
#3 (permalink) |
Moderator
you can get at it w/o removing the mount.... the part that bolts to the front cover hits the subframe when you try to remove it and b/c of the pickup, and needing to wiggle the pan off, you have to lift the engine out ~3-6" IIRC
__________________ any asshole can make a v8 fast It takes a special breed oof stupid/crazy asshole to make a v6 fast http:www.hellfiremotorsports.com/garage |
#4 (permalink) | |
Moderator
True. You might want to pick up a replacement windage tray too. Considering the age and exposure to heat I wouldn't be surprised if yours cracks out when you go to remove the pan.
#6 (permalink) | |
Moderator
Technically it's reuseable. And the gasket is built into the windage tray. Not the other way around. But yeah. Good idea to replace it.
| Sponsored Links | |
Advertisement | |
| replacing headers | 96impala | 6th Gen Engine Performance | 3 | 10-13-2009 03:24 PM |
| Replacing headunit need some help... | Impala_b | Audio, Video, and Electronics | 4 | 08-31-2009 12:14 PM |
| Replacing brakes | chrismoya | 7th Gen Suspension | 5 | 02-28-2009 06:40 PM |
| DIY-Replacing your Cat Converter | JamesM | Resource Center | 0 | 11-15-2008 11:08 PM |
| Replacing The Rear 6x9's | TylerLorenz | Chevy Impala 7th Gen Discussion | 3 | 06-02-2008 10:30 PM |
