02 rough idle, intermittent hard start, no codes - Chevy Impala Forums
post #1 of (permalink) Old 09-17-2010, 04:06 PM Thread Starter
Like the title says, its the bosses car. It idles very rough, but doesn't seem to be missing, tune up done less than 25k ago, same problem before and after. Fuel filter replaced, plugs and wires, air filter, etc. Only codes it has thrown the whole time have been low coolant temp. Maybe needs an injector service? Anything I should look for in the live data?
As for the hard start, he tells me sometimes it just cranks and cranks and can take as much as 5 minutes to start, sometimes its fine. I farted on his hood for him and its been fine ever since, but he isn't buying that fix for some reason...
post #2 of (permalink) Old 09-17-2010, 07:08 PM
Quoted: 15 Post(s)
What about transmission service? Also, how many miles?
donmateo is offline
post #3 of (permalink) Old 09-17-2010, 08:09 PM
77Impala's Avatar
Quoted: 8 Post(s)
What is the fuel pressure? Is it in specs? Sounds like a low fuel pressure or an issue with the fuel pressure check valve that is supposed to keep the fuel pressure in the line while the engine is off. If that valve fails the the fuel pressure will leak off and can take a while to build up especially if the pump is weak.
1977 Chevrolet Impala Sedan
1989 GMC C1500 Sierra ECSB
77Impala is offline
post #4 of (permalink) Old 09-18-2010, 08:24 AM
dyslexic doggie's Avatar
after my experience with my 01 ls, i have to concur with checking the fuel pressure,
turn the key to the on position it should be about 50. at the schrader valve.
dance dance everyone!....ok maybe not you.
dyslexic doggie is offline
post #5 of (permalink) Old 09-18-2010, 04:58 PM Thread Starter
Everything has been serviced regularly, but the car does have 244,xxx on it. I don't have a fuel pressure gauge, but maybe I can get one.
post #6 of (permalink) Old 09-18-2010, 07:16 PM
I paid around 40bucks for mine , but to be honest, Im glad I bought it. I know I will have it for the future.
post #7 of (permalink) Old 09-18-2010, 08:28 PM
77Impala's Avatar
Quoted: 8 Post(s)
Originally Posted by dyslexic doggie View Post
I paid around 40bucks for mine...
Same here. A bargain for how useful they are.
77Impala is offline
post #8 of (permalink) Old 10-15-2010, 02:12 PM Thread Starter
Still haven't put a pressure gauge on it, but there are some codes and freeze frame data with them. P0128 (it throws this every now and then just for shits and gigs), P0620, P1189 and P1811.
Fuel sys 1 closed loop, load value 12.16%, temp 170.6, short term trim 0, long term -5.47%, IMAP 24.81hg, RPMs 1160, 41.01mph, MAF 2.45lbs/min, TPS 10.2%
Thats all so far, other than that, car runs the same. Hasn't done the no-start thing for awhile though, seemed to be more of a cold weather issue.
post #9 of (permalink) Old 10-15-2010, 03:21 PM Thread Starter
btw, not sure about the 1189 and 1811 codes, but the 620 was probably just from the belt slipping the other day when I washed the engine.
post #10 of (permalink) Old 10-15-2010, 04:09 PM
77Impala's Avatar
Quoted: 8 Post(s)
P1189 Oil pressure switch, wonder if it had been unplugged while the engine was running during a test or check.
P1181 pressure control solenoid
77Impala is offline
post #11 of (permalink) Old 10-20-2010, 03:49 PM Thread Starter
Not on purpose... probably a loose wire, wouldn't be the first. I had to redo the pigtails on the oil level sender and the a/c compressor already on this car.
post #12 of (permalink) Old 03-29-2011, 01:43 PM
Kismet's Avatar
Pressure Control Solenoid
Hi. My 2003 Pressure Control Solenoid was changed by Chevrolet & it is still doing the same thing. RPM are going but car won't move & then hard shifts.
Kismet is offline
post #13 of (permalink) Old 03-29-2011, 04:16 PM
77Impala's Avatar
Quoted: 8 Post(s)
Did they replace all the solenoids or just the one?
77Impala is offline
car rough idle for a second!!!!!WTF!!!! lopez Chevy Impala 7th Gen Discussion 11 09-18-2010 04:17 AM
Rough Idle 1stCaprice Chevy Caprice 7 06-25-2010 11:51 AM
just did plugs and wires, now a rough idle stevo1390 Chevy Impala 7th Gen Discussion 5 12-04-2009 01:29 PM
Hesitation and Rough Idle Project 64 Impala Wagon 1st - 5th Gen Engine Performance 11 07-01-2009 03:09 PM
Rough running intermittent taeLT194 Mechanical and Electrical Problems 8 05-24-2009 04:55 AM
