3.4L misfire - Chevy Impala Forums
post #1 of (permalink) Old 05-06-2010, 12:52 PM Thread Starter
Jack's Avatar
3.4L misfire
2000 basic 3.4L, engine running *rough*, happened all of a sudden like. Stopped by Autozone and they read the code (the check engine light was flashing) and the code said (I forget the exact number) #3 cylinder was misfiring. I put new plugs and wires on last month and it was running perfectly until this misfire thing. I replace the coil block on a whim, but that didn't change anything. The other two possibilities are vacuum leak and fuel injector. I can't rule out a vacuum leak except to say nothing is disconnected and all the hoses seem to be in good shape. I'm thinking I'm going to change the #3 injector, so, it looks like I need to remove the TB and UIM. Is there a gasket kit for the manifold? or do I need some secret agent gasket compound? I would appreciate your thoughts.
Jack is offline
post #2 of (permalink) Old 05-06-2010, 01:02 PM
Moderator
wanderson75's Avatar
have you pulled the #3 plug to check it's condition first? And what kind of plugs are you using?
–adjective
wanderson75 is offline
post #3 of (permalink) Old 05-06-2010, 01:26 PM Thread Starter
Jack's Avatar
I've just pulled the #3 plug. It's black with carbon, so it appears to be fouled. All the plugs are one month old, AC-Delco 41-940's.
Even though I've changed the coil block, I don't know if this plug wire is good even though it's brand new, and I'm not sure how to check it.
Thanks
Jack is offline
post #4 of (permalink) Old 05-06-2010, 01:34 PM
Moderator
Check the other plugs as well. It's very possible that the bad coil caused that plug to foul out. But I'd look at the others as well just to doubly check.
–adjective
post #5 of (permalink) Old 05-06-2010, 01:46 PM Thread Starter
Jack's Avatar
Well, the #3 spark plug is firing, I turned the engine over and watched the plug fire. I'm not sure if that is scientific or not. I'm pulling the other plugs just to see how they look. Thanks.
Jack is offline
post #6 of (permalink) Old 05-06-2010, 02:11 PM Thread Starter
Jack's Avatar
Well, obviously the 'normal' things are never what's wrong for me. I've gone about as far as I can go with troubleshooting. Every cylinder is firing except #3, it's not intermittent, it's all the time. The spark plug wires are good, the plugs are good. I wonder what the most 'probable' thing would be? I think this one's heading to the shop next week.
Jack is offline
post #7 of (permalink) Old 05-07-2010, 06:57 AM
Moderator
Go cheap and work your way up. Replace plug #3 as well as the wire. A cat that is starting to go bad can also cause misfires on the #3 as well. You can have a shop do a back pressure test.
–adjective
post #8 of (permalink) Old 05-07-2010, 07:03 AM Thread Starter
Jack's Avatar
I'll replace the plug and wire today, I guess I don't need to assume that the new parts are any good :~) Hopefully luck will be with me. I hate to think of replacing the cat, I hear that is very expensive.
Jack is offline
post #9 of (permalink) Old 05-12-2010, 08:02 AM Thread Starter
Jack's Avatar
wanderson75, just wanted to say thanks for your help. I probably would have spent some unecessary money, I never in a million years would have thought the new plug wire was bad. I replaced the #3 wire and all is well now.
Jack is offline
post #10 of (permalink) Old 05-12-2010, 08:25 AM
Moderator
Good to hear it man.
–adjective
post #11 of (permalink) Old 05-13-2010, 10:16 AM
Lingenfelter's Avatar
I had 8psi of back pressure when my cat plugged...
Top 10 poster at NAIOA.
Top 10 poster at NewImpala.
Lingenfelter is offline
eng misfire and issues hotstf31 7th Gen Engine Performance 2 04-28-2010 04:27 PM
Misfire in cylinder 1 tt455 Chevy Impala 8th Gen Discussion 3 08-17-2009 09:22 PM
LT1 just started to misfire and pop with no power. gentner8 Chevy Impala 6th Gen Discussion 10 04-29-2009 02:46 AM
96 impala misfire? miguel d Chevy Impala Discussion 6 01-30-2009 02:22 AM
Misfire Codes PJT77 Autocare and Maintenance 0 12-04-2008 06:43 AM
