Chevy Impala SS Forums
Go Back   Chevy Impala SS Forums > Performance and Technical > Chevy Impala 7th Gen Discussion
Old 03-19-2010, 04:17 PM   #1 (permalink)
roundthirteen's Avatar
Send a message via AIM to roundthirteen
popping in the front end
Remove this ad!
I just put on new outer tie rods and I know I need new front bearings (but what would cause a popping sound (almost like a bad motor mount) when you are bringing the car out of a hard right hand turn (like going down a parking ramp). It seems to happen when you are letting the steering wheel return to center from right.
My car's not a sleeper, it's a hibernator.
No OHC + no aluminum='s no problems
roundthirteen is offline
Old 03-21-2010, 07:32 AM   #2 (permalink)
No ideas? Could it be a bad CV?
Old 03-21-2010, 06:08 PM   #3 (permalink)
77Impala's Avatar
Check that the steering Rack is bolted down tight. Any loose mounting bolts can cause it to shift some and make that type of noise.
1977 Impala Sedan, 5.0L, TH200, 3.25:1, 82K miles, 27 Lifetime Warranty Parts. Does not like Dodge Pickups rear bumpers!
1997 Dodge Ram B2500, 5.2L, 36RH, 3.21:1, 352K miles, 10 Lifetime Warranty Parts.
77Impala is offline
Old 03-22-2010, 05:48 AM   #4 (permalink)
wanderson75's Avatar
This can also be caused by the cradle bolts coming loose. I would check the torque on them. Could also be the diagonal braces not torqued to spec as well. I'll have Kevin post up torque specs since I don't have the manuals at work with me.
–adjective
wanderson75 is offline
Old 03-22-2010, 06:47 AM   #5 (permalink)
Frame Bolts
165 N·m
122 lb ft
–adjective
IS the front end the same on the 65-81? amstaff72 Chevy Caprice 3 12-16-2009 12:43 AM
Need a new front fender???????? 94loveboat Buick Roadmaster 1 09-15-2009 05:48 PM
2003 Impala popping noise fraztn Chevy Impala Discussion 0 10-18-2008 06:52 PM
Removing front and rear bumpers, grille and front valence on '66 66_on_blocks Impala 1st - 5th Gen Discussion 0 08-07-2008 03:06 PM
any one know what causes a popping or clunking noise ,when you turn the... evohman51 Mechanical and Electrical Problems 6 09-02-2007 09:13 PM
