Bucking/no accel - Chevy Impala Forums
post #1 of (permalink) Old 11-19-2009, 04:18 PM Thread Starter
wrench's Avatar
Bucking/no accel
I have a 03 LS that is having problem. It poped the check engine light right when it started running like crap. And has steadly gotten worse to the point it is now. Which is when you hit the gas it sounds like its choking and will not accel barely. I went and got the codes pulled.
First was p0404 (egr system fault)
Next was p0128 (Coolant temp is always low)
I replaced the EGR, full tune up(spark plugs, wires, fuel filter, and air filter)
Still have same problem. Also replaced the purge valve. Not sure if thats the name. I have always called them feedback sensors(jeep lingo)
Some people have asked me about the MAF and that was replace about a year ago due to getting water in the intake.
So now im stuck and dont know where to go with it.
Any suggestions
wrench is offline
post #2 of (permalink) Old 11-20-2009, 09:15 AM
Moderator
wanderson75's Avatar
Are you still getting the same codes as well?
–adjective
wanderson75 is offline
post #3 of (permalink) Old 11-21-2009, 07:27 AM
HERD546's Avatar
How Many miles are on the Impala? It may be a plugged cat, when my 92 Caprice with 150000 miles started running like crap I found that the cat was bad.. Also have you replaced the fuel filter?
Has the thermostat been replaced? It may be stuck open, if you do look to the 160 Deg stat..
You may want to buy a OBDII code reader that has a display they sell for $ 80.00 or so..
PAUL R DUMDIE JR.
HERD546 ISSCA 2158
W9DWP AZISSO 460
www.theherd.com
1996 DGGM IMPALA SS
1995 BLACK Carprice SS WAGON SOLD..
1992 Dk Gray Caprice SS WAGON SOLD..
2008 Impala LT
2002 Impala LS
2009 White TAHOE Z56 PPV..
HERD Club Vice President & Events Coordinator.
HERD546 is offline
post #4 of (permalink) Old 11-21-2009, 09:22 AM Thread Starter
wrench's Avatar
Same codes are popping up and i changed the fuel filter. Just put the tank back in just due to the milage wanted to check out the fuel pump. The car has 163000 miles on it. I wanted to check the cat out but it all welding in. So i have to take it up to the shop and cut it off and take a look at it. The coolant stuff is that the switch is bad waiting on one to come in. Im also doing the theromostat at the same time.
Right now its still doing the same though
wrench is offline
post #5 of (permalink) Old 11-24-2009, 08:28 AM
Moderator
Have the shop do a back pressure test on it. I agree that it's most likely a clogged cat at this point.
–adjective
post #6 of (permalink) Old 11-24-2009, 09:02 AM
wedebrook's Avatar
I'll put $5 on a clogged cat.
Rule #2: It's wrong to be French.
wedebrook is offline
post #7 of (permalink) Old 11-24-2009, 10:48 AM
Lingenfelter's Avatar
Backed up kitty.
Top 10 poster at NAIOA.
Top 10 poster at NewImpala.
Lingenfelter is offline
post #8 of (permalink) Old 11-24-2009, 12:07 PM
Moderator
–adjective
03 Impala hard shifting/bucking W.P._Turbocars 7th Gen Drivetrain 28 09-20-2009 08:29 PM
Accel distributer rotor tight? dintymoore Chevy Caprice 13 08-04-2009 05:47 PM
Chevy truck bucking/mis-firing? hsd7446 Automotive Discussion 1 09-12-2007 08:03 AM
1996 buick 3800 eng supercharged, having problem with bucking when driving , shalagre Automotive Discussion 1 09-08-2007 12:25 PM
