Location of Coolant Temp Sensor - Chevy Impala Forums
post #1 of (permalink) Old 03-04-2009, 10:53 AM Thread Starter
lenabena's Avatar
Hello All, I'm new and just wanted to know if anybody knew where the Coolant Temp Sensor was located. I don't want to spend crazy money getting a $12 part installed on my car if I can do it my self or at least direct my mechanic to exactly where it is. Thanks for all help.
lenabena is offline
post #2 of (permalink) Old 03-04-2009, 02:16 PM
blusail's Avatar
Its on the lower intake manifold on the driver side. It has a 2 pin connector going into it.
blusail is offline
post #3 of (permalink) Old 03-04-2009, 08:44 PM
Fearless 2005's Avatar
What made you think it was bad? Just asking because these cars have problems with the cluster going out and making you think it's other things lol.
Fearless 2005 is offline
post #4 of (permalink) Old 03-24-2009, 07:46 AM
minofmusic's Avatar
I think i need mine changed too
my temp guage floats into the red while im stopped and while im driving it goes back to normal and then rises and falls again
minofmusic is offline
post #5 of (permalink) Old 09-02-2009, 10:26 AM
robmora27's Avatar
location of the coolant sensor
i was tring to find it on my car the check engine light came on and had it checked and it said the sensor is bad can you help me find it
robmora27 is offline
post #6 of (permalink) Old 09-02-2009, 10:28 AM
robmora27's Avatar
Angry pictures may be would be cool
i was trying to look on line for pictures of the location but no such help
post #7 of (permalink) Old 09-02-2009, 11:46 AM
CaStylin's Avatar
The T-stat a pretty easy install on the 3800, if your gonna change it i would suggest getting a 180* stat from ZZP or another w-body site
but to me the rising and falling temps seem to be a fan issue over a t-stat issue... I may be wrong but the car moving isn't going to affect the opening and closing of the T-stat. Have you checked to see if fan #1 is strongly moving at idle ? I had a fan #1 go bad on me which started to car to over heat because the fan was moving slower then normal, when temps would get to a certain point (as dictated by the PCM) then fan # 2 would turn on and help out with to lower the temps... the speed of the car would help rotate fan #1 as well.
CaStylin - Lots of show... Even more go
~1968 Impala - 327, more to come soon
~1979 Monte Carlo - Stock for now
~2003 Impala - T61 Turbo, intercooler, Plog, much much more
CaStylin is offline
post #8 of (permalink) Old 06-01-2015, 02:30 PM
3rdstreetfreeway's Avatar
i know this is late, but for future referrence, flush your coolant, change termostat and temp. sensor. It will cost you less than $50 for the parts. DONNOT buy your parts from autozone, parts look the same but they blew my intake in less than an hour after replacing them. the Temp. sensor is right in front of the termostat below the throttle body on the right side of the engine. Replace both, and again do not buy your parts from autozone. Also check your fuses in the lower fuse box under the hood, 9/10 times you will need to replace the 25AMP fuse ( it's clear).Your heating problem is Dextron, it clogs up your coolant passage, use regular 50/50 antifreeze instead. After you have fixed your issues, your best bet is to get rid of your impala ASAP.
3rdstreetfreeway is offline
LinkBack to this Thread: http://www.impalaforums.com/chevy-impala-7th-gen-discussion/234823-location-of-coolant-temp-sensor.html
Location of Coolant Temp Sensor - Chevy Impala SS Forums This thread Refback 01-09-2011 11:03 AM
02 Chevy Impala: Low coolant light on, temp gauge acts funny, Plenty of coolant.? Nate P Mechanical and Electrical Problems 4 04-05-2011 10:51 AM
Pressure Control Module Location? LaFrance454 7th Gen Engine Performance 3 01-21-2009 06:51 PM
94 caprice 5.7 LT-1 MAF sensor location GETEJO Chevy Caprice 1 12-01-2008 07:14 AM
95 caprice speed sensor wire location? Clifford C Chevy Caprice 5 11-13-2008 01:24 PM
Engine Coolant Sensor tones2SS Chevy Impala 7th Gen Discussion 1 03-06-2008 07:12 PM
