Gas gauge does not work - Chevy Impala Forums
post #1 of (permalink) Old 12-21-2008, 01:48 PM Thread Starter
mmanter's Avatar
I have read about problems with the gas gauges on the generation Impala my dad has, and his is not immune.
When we got the car it would work intermittently, but now the gas gauge needle is always pointing around the 6:00 position. Is this probably a problem with the cluster or something at the fuel pump itself?
Any info that can be sent my way is appreciated so I can fix the problem.
Matt Manter
2004 Impala
mmanter is offline
post #2 of (permalink) Old 12-25-2008, 11:35 AM
Fearless 2005's Avatar
Are you getting any CEL's? If your not then I am guessing your gauge is bad. Or even possibly a ground somewhere.
My coolant gauge is not working and I have no CEL's. And your right, these cars are infamous for those gauges.
Fearless 2005 is offline
post #3 of (permalink) Old 12-25-2008, 11:39 AM
It may also be a sender in the gas tank......
I highly doubt your pump is bad. If it was, then it wouldn't be preasurizing fuel through to the injectors.
post #4 of (permalink) Old 12-26-2008, 01:34 PM
blusail's Avatar
A fix for the problem could also be a level sensor in the tank is getting hung up and not reading correctly
blusail is offline
post #5 of (permalink) Old 12-28-2008, 08:20 PM Thread Starter
mmanter's Avatar
Thanks for the replies guys.
There was an Impala at the junkyard so I went ahead & grabbed the fuel level sensor off the pump. The cluster is the deluxe with the tach or I would ahve grabbed that as well.
Will the speedo swap out & retain the mileage if I grab the cluster?
Matt Manter
2004 Impala
mmanter is offline
post #6 of (permalink) Old 12-28-2008, 08:22 PM Thread Starter
mmanter's Avatar
forgot to mention I did test the replacement sensor & it doesn't seem to have any dead spots & the resistance varies depending on the position of the float arm. I'll update after I swap it out on wednesday.
Matt Manter
2004 Impala
mmanter is offline
post #7 of (permalink) Old 12-28-2008, 08:23 PM Thread Starter
mmanter's Avatar
Now that I think of it, he has an intermittent check engine light. Currently it is out but it has been on before & when I was gonna check the code it went out.
Matt Manter
2004 Impala
mmanter is offline
post #8 of (permalink) Old 02-02-2009, 12:44 PM
dorman68's Avatar
The fuel level sensor in the tank is a common failure part.
dorman68 is offline
post #9 of (permalink) Old 02-03-2009, 01:48 AM
GTR
GTR's Avatar
Your needle is suffering from a condition called "limp dick syndrome".
GTR is offline
post #10 of (permalink) Old 02-03-2009, 04:21 AM
capricewiz's Avatar
You can buy just a fuel level sensor from the dealer for like $30
capricewiz is offline
post #11 of (permalink) Old 02-03-2009, 04:55 AM
dorman68's Avatar
capricewiz,
Wow thats a great price. My cousing has an 04 Impala and his gauge was not working and the local dealer quoted me $180.00 just for the level sensor by itself. Do you know where I can get one for $30 or do you have an part number I can order from the dealer?
dorman68 is offline
post #12 of (permalink) Old 02-03-2009, 02:51 PM
blusail's Avatar
180 Is The List Price On That Level Sensor And The Part Number Is 89060197
blusail is offline
post #13 of (permalink) Old 02-04-2009, 05:24 AM
dorman68's Avatar
Thanks blusail
dorman68 is offline
post #14 of (permalink) Old 02-04-2009, 11:48 AM
bad03xtreme's Avatar
I am looking at an 04' SS and the photo online has the same issue you are describing here is a photo they have posted online. Do you think it is the level sensor issue and I should try and get them to knock the price down a bit.
bad03xtreme is offline
post #15 of (permalink) Old 02-04-2009, 02:54 PM
blusail's Avatar
I would say that looks like a cluster problem and not the level sensor
blusail is offline
My 2004 Chevy Impala is having gauge problems. The gas gauge is off, the... astrokien Mechanical and Electrical Problems 7 09-30-2008 07:53 AM
My 2008 Chevy Impala LS,the gas gauge wont work? Henry M Chevy Impala Discussion 3 09-15-2008 09:35 AM
fuel gauge doesn't work on impala? jazam Chevy Impala Discussion 1 08-12-2008 09:27 PM
gauge wiring for the 66 wjforbes Automotive Discussion 0 04-11-2008 05:50 PM
gmc canyon all three lights work on tailight assembly but the tail light dont work.? denny b Automotive Discussion 1 09-07-2007 05:56 AM
