Temperature Gauge problem - Chevy Impala Forums
post #1 of (permalink) Old 03-30-2008, 10:23 AM Thread Starter
P-impala's Avatar
I'm new here i have a 2001 impala 3.4 and my temperature gauge needle just sits still it doesn even move even if i start the car do you guys think its a fuse or something?
P-impala is offline
post #2 of (permalink) Old 03-30-2008, 11:33 AM
77Impala's Avatar
Quoted: 6 Post(s)
Depends where the gage needle actually sits. If at the cold position yes check the fuse but I doubt that is the problem if all other gages are working. Most likely the sensor is bad or the wire from the sensor to the gage is bad. Sometimes it is the positive wire or ground at the gage and once in a while it is the gage itself.
77Impala is offline
post #3 of (permalink) Old 03-31-2008, 07:54 PM Thread Starter
P-impala's Avatar
Hi, yes it just sits on the cold position when i start the car it twiches only once but it doesn't go up and my local street mechanic said that it ist the sensor b/c i recently change it and since i dont have the fuse box covers im thinking that it might be a fuse but i dont know which one or it could be the wire as you stated.
P-impala is offline
post #4 of (permalink) Old 03-31-2008, 08:13 PM
77Impala's Avatar
Quoted: 6 Post(s)
First wire I would check is the wire from the sensor to the dash cluster. Many times this wire breaks, disconnect the wire from the sensor and using a DVM meter on the ohm (resistance) setting and see if the wire is shorted to the body of the car, or if it is broken (open circuit). Then I would check that the gage has power and that the ground wire is working. If not in the wiring then it is the gage is faulty. If you need more help just let me know.
77Impala is offline
Chevy Impala Temperature gauge problems? Matt Mechanical and Electrical Problems 2 11-04-2010 02:53 PM
RPM Gauge stopped working and problem with my headlights.... snwbrdrugbychica8 Automotive Discussion 1 12-28-2008 07:14 AM
'05 Chevy Impala Temperature Problem? ChristianGirl_Melissa Chevy Impala Discussion 1 06-08-2008 02:23 AM
2004 chevy impala transmission problem....car won't move until temperature is... adren c Mechanical and Electrical Problems 3 01-22-2008 01:02 PM
vauxhall cavalier 1993 temperature gauge not working? ajb16 Automotive Discussion 1 09-09-2007 11:00 AM
