Key Fob wont program? - Chevy Impala Forums
post #1 of (permalink) Old 03-11-2017, 02:03 PM Thread Starter
Lrndthehardway's Avatar
We bought this 04 LS used but it didnt have a key fob so I ordered one on fleabay thats supposed to be for this car, and it wont program. Ive done the correct procedure I found here and other places with no luck. I read there could be an issue with the receiver? But I havent found any info where its at, or how to check it, any help
Lrndthehardway is offline
post #2 of (permalink) Old 03-11-2017, 02:18 PM
Quoted: 50 Post(s)
I recently bought a genuine GM fob for my brother's 2001 Monte Carlo and it programmed on the first attempt.
I would return the knock-off (probably made in China.....) fob and buy a genuine new GM fob. They are not very expensive.
Good luck.
post #3 of (permalink) Old 03-11-2017, 02:25 PM Thread Starter
Thanks Ive already started the process, Im hoping thats the problem, Ive ordered the cheap ones before and have never had a problem but I guess I was just lucky. Getting sick of all the little things Im finding with this car lol
post #4 of (permalink) Old 03-11-2017, 02:26 PM Thread Starter
Is it possible I dont have the keyless entry or did all 04 LSs have it as standard?
post #5 of (permalink) Old 03-11-2017, 02:49 PM
Revo2Maxx2016's Avatar
Quoted: 80 Post(s)
LS 04 should be standard. Look on your RPO codes in trunk for AU0. ON the remote you want to make sure that on the back it has the same digits that your OEM one has/had.
For the Impala 01-05 should use 10443537 for ACDELCO. or C02028 for knockoff
James
For the 00 Impala you can't use that remote for 01-05
James
Revo2Maxx2016 is offline
post #6 of (permalink) Old 03-11-2017, 03:40 PM Thread Starter
Car didnt come with a fob, but it looks like it was standard on these, didnt look at the rpo code yet but everything ive found says it was standard, to damn cold at 15 degrees to be outside fiddling around looking for something that you dont know where to look for lol, I saw under the carpet passenger side eff that, to cold lol. So im thinking about going out and replacing this ignition lock cylinder but then I started thinking that id like to keep the original key so idk, rekey it to old key, or just use 2 keys??? hmmm... I guess I need to figure out what happens if I rekey new cylinder, but have the same issues with the key being a pita to turn because of the tumblers or whatever, I swap over...
post #7 of (permalink) Old 03-20-2017, 04:05 PM
hg3300's Avatar
Quoted: 13 Post(s)
Go to a GM dealership. I went and they programmed my FOBs for free.
2003 Chevrolet Impala Base
hg3300 is offline
post #8 of (permalink) Old 03-20-2017, 04:15 PM Thread Starter
I appreciate the input. I already sent it back to the person I bought it from and am getting some genuine gm ones, even cheaper than this other one was, if I have the same problem then Ill know its something in the car and not me, to easy to mess it up though, unless its the receiver in the car
post #9 of (permalink) Old 03-30-2017, 06:30 PM
hg3300's Avatar
Quoted: 13 Post(s)
Mine was the damn receiver. For whatever reason, the factory radio won't go into the customization menu.
hg3300 is offline
post #10 of (permalink) Old 03-30-2017, 08:30 PM
Quoted: 80 Post(s)
To find your RPO code there is a Paper that is attached to your Trunk lid on the Left side. It will be white with Black letters. At the top it will have the VIN. Then there is loads of 3 digits codes. AU0 is for Keyless. IT would be at the top of the list. Hope your Remote comes for you soon and this thing works out for you in the End.
James
James
Program Key Fob Cost chevy67 Chevy Impala 8th Gen Discussion 3 08-27-2016 01:47 PM
Key fob does not program Hyperbomb64 Audio, Video, and Electronics 19 02-26-2013 09:35 PM
How do I program a key fob for my 2005 Chevy Impala? Rocketrod65 Chevy Impala Discussion 1 02-26-2013 05:15 PM
Program key fob from different model years? BigCee Chevy Impala 7th Gen Discussion 10 11-01-2012 09:46 PM
Program key fob help please aja8888 Chevy Impala 7th Gen Discussion 5 05-08-2010 08:10 AM
