Cooling fans not coming on at the right time - Chevy Impala Forums
post #1 of (permalink) Old 04-03-2013, 06:39 PM Thread Starter
gackman's Avatar
Hello
I am new here wonding if someone knows about this problem. I have a 95 impala that is over heating. The cooling fans are coming on but not until it starts to over heat. I took the car into a shop and the guy at hte shop says the fans turn on at 229 degrees and shut off at 219 degrees. It looks like its over heating but its not. Thats what the guy at the shop told me and it didnt sound right to me can someone help
gackman is offline
post #2 of (permalink) Old 04-03-2013, 08:15 PM
The Unscrupulous Lt. Colonel
Crime Scene's Avatar
This is the wrong section, but to answer the question the mechanic is right. GM tuned our cars very high for the fans to come on just short of the red mark. Why is beyond me, but its perfectly normal. You can retune for the fans to come on at a much lower temp. My tune has the fans to cut on at a little over 180-190 degrees. HTH...
2001 Chevy Impala 3.4 - Traded
2004 Chevy Impala 3.4 - Traded
2002 Chevy Impala 3.4 - RIP 1.12.2011/ Ice Storm
1996 Chevy Impala SS - RIP 4.15.2012/ Asswipe
1996 Chevy Impala SS - Current
Crime Scene is offline
The Following User Says Thank You to Crime Scene For This Useful Post:
gackman (04-04-2013)
post #3 of (permalink) Old 04-04-2013, 08:05 AM Thread Starter
gackman's Avatar
Thank you
gackman is offline
post #4 of (permalink) Old 04-04-2013, 12:01 PM
Thread moved.
post #5 of (permalink) Old 04-04-2013, 01:25 PM
TWX
Drinks Gasoline
TWX's Avatar
You might want to check your cooling system pressure, you might have an internal-engine leak and with the lower pressure it may not work quite right.
TWX is offline
The Following User Says Thank You to TWX For This Useful Post:
post #6 of (permalink) Old 04-04-2013, 01:37 PM Thread Starter
gackman's Avatar
The guy at the shop did that he said it was fine. I was thinking should I hook up a manual fan switch? Or put a thermastat that runs cooler like 160 degrees?
gackman is offline
post #7 of (permalink) Old 04-05-2013, 12:41 PM
Best bet is a tune to turn the fans on at a lower temp.
gackman (04-05-2013)
post #8 of (permalink) Old 04-05-2013, 01:39 PM Thread Starter
gackman's Avatar
Crime Scene
yeah i was talking to Crime Scene about that im going to give it a go and see what happens ill keep you all up to date and thanks again.
gackman is offline
post #9 of (permalink) Old 04-05-2013, 10:25 PM
Every 2nd Matters
Papa D's Avatar
I posted on the moved thread already, but on these cars, if it is coming on just as the needle hits the red, the fans are working right. You can tune it to come on earlier.
Jackass of all Trades
Tri-9 Defined: 1994, 1995 or 1996 B-Body.
1994 9c1- Goodbye Barricade.
Papa D is offline
post #10 of (permalink) Old 04-09-2013, 10:10 PM Thread Starter
gackman's Avatar
So I got the new thermastat in today and it made a difference but I wish I could do some more to get the fans to kick on sooner.
gackman is offline
post #11 of (permalink) Old 04-10-2013, 11:49 AM
Tune is it man.
post #12 of (permalink) Old 04-10-2013, 07:22 PM
raSSbot's Avatar
Cool
If I am not mistaken, changing the stat to 160 is not going to make a difference unless you tune your PCM.
95 BBB
96 DGGM
Cali-SS
ISSCA # 2212
raSSbot is offline
post #13 of (permalink) Old 04-11-2013, 08:26 PM
Every 2nd Matters
Papa D's Avatar
No, it will make a difference, because you are opening the coolant flow earlier, thus helping it cool sooner.
Papa D is offline
post #14 of (permalink) Old 04-12-2013, 12:28 PM
Only if you're moving, at idle it won't matter. It's like doing half the job.
post #15 of (permalink) Old 04-13-2013, 09:13 PM
Gregg-O's Avatar
The primary fan should come on just above the 1/2 way mark, then shutoff just under the 1/2 way mark. the secondary won't come on until just before the first red mark. If all is working correctly, you should never see the sec. fan come on. ....meaning , it should never get that hot. Just becauce the prim. fan is turning doesn't mean it moving enough air.
Gregg-O is offline
Cooling fans Question jays94ss Chevy Impala 6th Gen Discussion 27 05-01-2014 08:43 PM
Fans not coming on..on time? gackman Autocare and Maintenance 8 04-19-2013 08:36 PM
cooling fans please help crackdown357 6th Gen Engine Performance 2 05-21-2011 11:31 PM
Cooling fans, HD or standard? JohnFl Chevy Impala 7th Gen Discussion 5 06-09-2010 05:41 PM
cooling fans BIGBOY34 Chevy Impala 7th Gen Discussion 2 04-16-2008 12:36 PM
