| Chevy Impala 6th Gen Discussion B-Body 1994, 1995, 1996. Discuss all Chevy Impala 6th Generation Performance and Technical Discussion here. |
& Barricade
![]() Join Date: Jan 2011
Need some deciding on next project...
My 94 has officially hit 300,000 miles. I am wanting to start putting some money into the suspension and the engine, but don't know which to start with. I am leaning towards the suspension since he kinda feels like a drunk school bus on pretty much everything I drive on. Straight lines at low speeds is actually scary. I know the steering linkage needs some work and the springs are shot on the left side.
The engine runs solid but has some oil containment issues. Thanks for the input. __________________ Jackass of all Trades Tri-9 Defined: 1994, 1995 or 1996 B-Body. ![]() 1994 9c1- 300,000 miles and counting. |
| Sponsored Links | |||
Advertisement | |||
Divine Autosound
![]() Join Date: Aug 2011
If the engine still seems to be in decent shape, and by that I mean if it isn't smoking or anything major, I would go with suspension. Suspension could end up being a life or death decision. If a tie rod busts or someyhing about it causes you to lose control, that might not end well. Engine could probably wait if it isn't showing any major signs of imminent failure.
#5 (permalink) |
Big Red Grocery Getter
![]() Join Date: May 2011
How extensively are you thinking about modifying the suspension? After you rebuild the steering, are you just going to do springs(and probably struts) or are you going to start looking into sway bars and the like too?
__________________ '09 Impala LS -SSC Lowering Springs -ZZP Front & Rear Strut Tower Brace -Dorman 927-100 Front Sway Bar -ZZP Shortened Dogbones -Addco 639 Rear Sway Bar -Turner Motorsports End Links |
#6 (permalink) |
& Barricade
I've got a 9c1. I like the Sway Bars already on it. I have Bilstein shocks already. I will probably go with some SS Springs, or maybe go a little lower. I know Impaler did a drop on his. I'm gonna pick his brain a little too.
#7 (permalink) |
have you considered new bushings too? Not poly bushings necessarily, but I would have to think that after 300k miles, most of the stock rubber bushings on the car are shot
#8 (permalink) |
![]() Join Date: Mar 2009
I replaced all my linkage a little while ago, pretty easy job. Saved a bundle by ordering everything from rockauto, would have been a lot more if I got it locally. Replace everything but the pitman arm, those don't wear. Now I need to do my control arm bushings and ball joints, not thrilled about that job... Oh, do your wheel bearings too, unless you replaced them recently. I also ordered sway bar bushings, but realized when I tried to put them on that I got the wrong ones. I got the 15/16 bushings, but I have the 1 1/8 bar like you do.
#9 (permalink) |
& Barricade
The body bushings are gonna bet done at some point. I did the Sway bar rebuild last summer. Thanks for the heads up about the pitman arm. I would have bought a new one of those too. Haven't got to get any parts, but I talked it over with my wife and she agreed to get the steering linkage done first then the rest of the suspension before the engine. that was probably the hardest part of the project... getting her on the same page. ;)
#10 (permalink) |
Advance Auto Parts has some incredible coupon codes. I play with their online purchase setup and coupon codes, and have learned how to maximize savings. I typically save about 30-40%. In store pick-up, or you can have it shipped to home if your order is over $75 after discounts. I normally mix and match the parts in a cart until I just hit a coupon code that is 40% off(is a certain dollar amount off, a certain dollar amount). Then place another order. Sometimes I have to spend another $2-3 on funnels to get a bigger discount.
Advance Auto Parts Coupon Codes: Get $28 Off w/ July 2012 Coupons, Promo Codes I would go with the suspension first. Inner/outer tie rods, Adjuster sleeves, idler arm, and a center link. If the ball joints haven't been done recently, I would inspect those very well and consider them. Then you also need to look at the control arm bushings. I have a 94 Caprice 9C1 that has new everything up front that was just mentioned. Except the control arm bushings. I can feel it shift back and forth rather strongly because the control arm bushings are toast. Mine only has 220k or so. The control arm bushings are a pain to do. It's worth considering to replace the entire arms. This is going to be an expensive, and labor intensive project. If doing front ball joints, now is the time to do front springs. I have recently seen a few SS sets for sale on ISSF. __________________ ~Cory Magner "My name is Cory, and I'm an addict." 95 DCM Buick RMS 14.21 @ 91.79 "Jesus" Blown Engine at 85k 95 DCM Buick RMS 13.52 @ 99.33 "The Doctor" Blown Engine at 180k ![]() 96 DGGM Buick RMW. 263k, still on the factory tranny. And 5 other LT1 powered land yachts Is there Rehab for this Sh*t?
| Sponsored Links | |
Advertisement | |
| Chevrolet : Impala project 64 Impala project great builder | RSS Bot | eBay Cars For Sale: Impala | 0 | 02-24-2011 10:40 AM |
| Soon to be Impala owner, Need help deciding | MJSchutt | Automotive Discussion | 15 | 02-10-2011 09:01 AM |
| Chevrolet : Impala Project Car 64 PROJECT CAR Collectors Dream Full Financing | RSS Bot | eBay Cars For Sale: Impala | 0 | 01-29-2011 05:20 PM |
| Soon To Be Impala Owner...need help deciding | Loud_Music | Chevy Impala Discussion | 6 | 04-18-2009 07:24 AM |
| I'm having problems deciding what car to get. My 05 Impala is no good. What... | Kevin | Mechanical and Electrical Problems | 3 | 10-01-2007 07:04 PM |
