'95 Caprice LT1 idling rough after plug change? - Chevy Impala Forums
Go Back   Chevy Impala Forums > Performance and Technical > Chevy Impala 6th Gen Discussion
Old 05-30-2012, 03:20 AM   #1 (permalink)
Erik the Red's Avatar
Hello,
I have a '95 Caprice with a LT1 and it just turned 80,000 miles. At 80,000 I change the Spark Plugs to AC Delco Platinums and had the Transmission Flushed and Serviced. After doing this to it, it has developed a rough idle. The car has always idled so smooth, so this was a big surprise. It seems to idle worse when its in gear. It has plenty of power and doesn't hesitate at all. It just runs rough at idle. All the plugs were gaped 0.050". There are no check engine lights on. I'm really confused here....
Thanks,
Erik
Erik the Red is offline   Reply With Quote
Old 05-30-2012, 05:06 AM   #2 (permalink)
Trying to gap platinum plugs is likely to damage the platinum pucks.
I would look for a plug wire problem.
Look underhood in the dark, maybe bring a spray bottle with water to try and induce arcing.
At one point there was a bad batch of Delco plugs out there that leaked combustion pressure and you could see a blue glow underhood around the plugs when running in the dark.
Old 05-31-2012, 07:37 PM   #3 (permalink)
The Unscrupulous Lt. Colonel
Crime Scene's Avatar
+1 with DJ. But also, make sure all your plug wires are where they are suppose to be, and not crossed by accident. Remember, wire boots must click twice.
2001 Chevy Impala 3.4 - Traded
2004 Chevy Impala 3.4 - Traded
2002 Chevy Impala 3.4 - RIP 1.12.2011/ Ice Storm
1996 Chevy Impala SS - RIP 4.15.2012/ Asswipe
1996 Chevy Impala SS - Current
Crime Scene is offline   Reply With Quote
Old 06-01-2012, 05:21 AM   #4 (permalink)
& Barricade
Papa D's Avatar
Listen to this man.
Also check this out. Crime Scene said exactly what I was going to suggest.
Jackass of all Trades
Tri-9 Defined: 1994, 1995 or 1996 B-Body.
1994 9c1- 300,000 miles and counting.
Papa D is offline   Reply With Quote
2006 3.9 Spark plug change peterbilt123 8th Gen Engine Performance 14 06-03-2012 02:14 AM
84 Caprice 305/700R4 idling rough HAFROD Mechanical and Electrical Problems 2 02-04-2012 09:28 PM
3.8L Spark Plug Change Instructions??? 54warrior Chevy Impala 7th Gen Discussion 6 04-11-2011 11:42 AM
DIY spark plug change video ljbrandt Autocare and Maintenance 6 08-08-2010 04:46 PM
advice - spark plug change elzorro Chevy Impala 6th Gen Discussion 7 05-26-2009 12:12 AM
