best tires? - Chevy Impala Forums
post #1 of (permalink) Old 05-26-2012, 07:04 PM Thread Starter
pinkdarknessimpalaSS's Avatar
best tires?
So I got a quote for new tires and it was around $800 for the 4 of them by a brand Ive never heard of or can even remember....is that too much or around normal cost? what would be my best bet as far as tires for my 96? Not racing, just reliable, long lasting tires. Sorry if this question has already been asked and answered.....
pinkdarknessimpalaSS is offline
post #2 of (permalink) Old 05-26-2012, 09:31 PM
4x4high's Avatar
From the searching i've done it looks like Kumho's are a good tire with people reporting some real good mileage out of them. I'll be needing tires soon and that looks like it may be the tire I go with. I just bought my car last month and it has Primewell PZ900 tires on it and so far they seem like a decent tire as well.
4x4high is offline
post #3 of (permalink) Old 05-27-2012, 02:16 PM
Jd1
The F*** Killer
Jd1's Avatar
Tire Products - Discount Tire Direct
Purchased:
1/3/12
09 Impala LT
Installed:
Alarm/Starter, 35% Tints, Black BowTie, Debadge, Trunk Lip, Window Visors, 18X8.5 Gunmetal/Polished ADR Battle EXE 245/45/18, 15MM Rear Spacers, Ebay Lowering Springs 1.7In, Monroe Struts & Mounts, Shorted Dog Bone, H.I.D 55W Ballast W/ 35W 5K Bulbs, Retrofit Black Headlights.
Future Mods:
Black Roof
~Jose
Jd1 is offline
post #4 of (permalink) Old 05-27-2012, 03:16 PM
waynes91's Avatar
being a new englander, well we get mother natures best at times do you get snow down your way? i heard to that kumhos are good too, i run fuzions, but they say its not a winter tire, she does go into hibernation for the winter anyway,
what ever u go with make sure the tire person uses a torque wrench, not the setting on the air gun or a torque stick etc..to tighten up the lug nuts, then u should recheck after 25-50 miles
waynes91 is offline
post #5 of (permalink) Old 05-28-2012, 11:31 AM
Every 2nd Matters
Papa D's Avatar
My favorite tires I have ever ran were Falkens. I paid about $400 for the set, but that was on my '92 Civic, about 10 years ago. Also, I was in California with no rain what so ever for a few years. I currently am running some cheap Hankooks on my 15" Steelies. They actually have a quite a bit of grip and over all performance. On the twisties, I can hold 40 mph twisties at around 60-65 mph without any loss of grip. On the wet roads they do good too.
Jackass of all Trades
Tri-9 Defined: 1994, 1995 or 1996 B-Body.
1994 9c1- Goodbye Barricade.
Papa D is offline
post #6 of (permalink) Old 05-28-2012, 01:09 PM
aka IMPALER
ekm1190's Avatar
I assume you're referring to a stock rim size? I have Kuhmo Ecsta ASX's and they're not too bad. They are OK in snow and are good in rain. Not really a performance tire, as they have a 400 tread ware rating.
PLEASE LIKE Hoosier Impala & Caprice Club
Check out my build thread:"Impala SSX Build"
Follow me on Instagram @emcsquared90
ekm1190 is offline
post #7 of (permalink) Old 05-28-2012, 01:21 PM
HERD546's Avatar
I have the BFGoodrich KDWS tires on my 96 Impala SS these were the replacement tires for The BFGoodrich Comp TA tires that the Impala's were shipped with new, in the Stock Size. P255/50ZR17
I have the Kuhmo ASX tires on my 95 Caprice SS Wagon.. On some pavements these tires can be noisy.. Also look at the Kuhmo SPT tires, they are a Ultra High Performance Summer tire.. They have a softer compound and have a UTQG of 320
The Kuhmo ASX has a UTQG of 420 and the BFGoodrich is a UTQG of 400
When I replace the tires on my Impala SS I will look at the Kuhmo SPT in a P285/40ZR17...
I have a few club members that run these all the way around on there Impala SS cars..
Here in the Chicago area we have a good relationship with the Discount Tire Stores they are great people to deal with.
Good Luck!
One other hot tip is to use the tape on wheel weights and not use the clip on wheel weights.. With today's Computer balance machines they work just as good.. Your Impala SS will look better and hopefully the wheels are not screwed up some one else..
PAUL R DUMDIE JR.
HERD546 ISSCA 2158
W9DWP AZISSO 460
www.theherd.com
1996 DGGM IMPALA SS
1995 BLACK Carprice SS WAGON SOLD..
1992 Dk Gray Caprice SS WAGON SOLD..
2008 Impala LT
2002 Impala LS
2009 White TAHOE Z56 PPV..
HERD Club Vice President & Events Coordinator.
HERD546 is offline
post #8 of (permalink) Old 05-28-2012, 01:23 PM
aka IMPALER
ekm1190's Avatar
Do you need to have the PCM reprogrammed or something changed to match the low profile side walls on the SPT's?
ekm1190 is offline
post #9 of (permalink) Old 05-28-2012, 01:32 PM
HERD546's Avatar
The 285/40-17 tires are 1 inch shorter than the 255/50-17 27.1 inch tire your speedometer will show faster than you are going.
PAUL R DUMDIE JR.
HERD546 ISSCA 2158
W9DWP AZISSO 460
www.theherd.com
1996 DGGM IMPALA SS
2008 Impala LT
2002 Impala LS
HERD546 is offline
post #10 of (permalink) Old 05-28-2012, 08:39 PM
aka IMPALER
ekm1190's Avatar
Ok that's what I thought, i assume you can adjust that by taking out your dash and messing with the speedo
ekm1190 is offline
post #11 of (permalink) Old 05-29-2012, 05:37 AM
HERD546's Avatar
If you have a GPS you can have an idea of your speed is when you are showing 60 MPH. You may be going 55 when it shows 60.. A tuner can adjust your speedometer to correct for this.
PAUL R DUMDIE JR.
HERD546 ISSCA 2158
W9DWP AZISSO 460
www.theherd.com
1996 DGGM IMPALA SS
2008 Impala LT
2002 Impala LS
HERD546 is offline
post #12 of (permalink) Old 05-29-2012, 01:33 PM
A couple quick notes, about the torquing, yes using an actual torque wrench is best, but re-checking after 25-50 miles is only necessary with new wheels. New wheels will compress slightly where the lugs make contact, thus the need for re-torque, this is not an issue with new tires since the wheels are the same. About treadwear ratings, there is no industry standard on traction or treadwear ratings, they are all made up by the individual tire manufacturers, so using them as a comparison only works when comparing models from the same make.
post #13 of (permalink) Old 05-29-2012, 06:47 PM
waynes91's Avatar
could be a good time to check out the front end ,ball joints, tie rod ends idle arm etc prior to getting new tires, then you be all set for a front end alinement later
waynes91 is offline
post #14 of (permalink) Old 06-12-2012, 09:36 AM
fatvet's Avatar
Send a message via AIM to fatvet
the next set i am trying solely based on COST
RikenŽ Raptor
EDIT:
a place to check tire ratings
http://www.safercar.gov/Vehicle+Shop...s/Tires+Rating
-ALF out....
'96 WX3 DGGM ISSCA # 01978 #7635 SS on the line http://www.cardomain.com/ride/2386222/1
Bilstein 0929/1104 odom fade mod, FB&HP delete,Pypes-X,Spintech Super Pro Streets, lower bushing mod,Stealth Brake Bolt,Bonnies,SS-Studio TB boot,9C1 air dams
'69 vert stingray
'00 1200C sportster with V&H Straight shots !!
fatvet is offline
post #15 of (permalink) Old 06-12-2012, 01:37 PM
aka IMPALER
ekm1190's Avatar
that's a very reasonable price... i like the tread pattern as well
ekm1190 is offline
LinkBack to this Thread: http://www.impalaforums.com/chevy-impala-6th-gen-discussion/324670-best-tires.html
best tires? - Chevy Impala Forums This thread Refback 05-27-2012 07:06 AM
Looking for some stock caprice rims and tires for my 9c1 tires. blizzy21 Private For Sale Classifieds 0 09-06-2011 07:18 PM
SS Tires kmad61 Chevy Impala 8th Gen Discussion 6 07-29-2011 08:33 PM
What are the best tires? Mike96ss Wheels and Tires 19 10-02-2010 11:00 AM
tires.. impala05 Wheels and Tires 11 08-28-2009 12:43 PM
Tires impala05 Automotive Discussion 3 11-12-2008 10:31 AM
