power steering pump rebuild kit - Chevy Impala Forums
Go Back   Chevy Impala Forums > Performance and Technical > Chevy Impala 6th Gen Discussion
Old 12-04-2009, 09:42 PM   #1 (permalink)
blunts415's Avatar
ok so yea my power steering pump is out for sure. i know where to buy a rebuild kit for it would i need any special tools? how hard would it be and would it prolly come with instructions? is it worth my money? or should i not even bother and buy a brand new pump? (limited funds)
blunts415 is offline   Reply With Quote
Old 12-05-2009, 08:44 AM   #2 (permalink)
ssety's Avatar
I don't think replacing the pump will be complicated. I preformed a service on my 96' SS that you may want to do after you install the new pump. I took a turkey baster, one quart of new power steering fluid and flushed my power steering fluid. I jacked up the front of the car, with turkey baster, sucked out all the fluid from the resivoir, refilled it to the correct (cold) level, put the check stick cap back on, started the car and turned the steering wheel from lock to lock ten times. then I repeated the proccess until the fluid that I was removing was as clean as the new fluid I was putting in. I did this service as a preventative measure. You may want to do it since you are going to install a new pump. It is so simple, a cave man could do it!
good luck
"fill'er up & check the gas!"
ssety is offline   Reply With Quote
Old 12-05-2009, 10:31 AM   #3 (permalink)
blunts415's Avatar
good luck
thanks for the info but it didnt really answer my question at all heh.
Old 12-05-2009, 10:42 AM   #4 (permalink)
So Y Dont U Go To The Parts Store After U Take Off Your Old Pump And Look At The Rebuild Kit For Yourself And See It U Need A Specialtool Or If U Should Buy A New One , O And If It Comes W/ Instructions.... Ive Repaired Master Cylinders B4 And I Believe That Came W/ Instructions
4 B BODIES
2 SOLD CAPRICES
POPIMPIN CUSTOMS I.N.C is offline   Reply With Quote
Old 12-05-2009, 03:42 PM   #5 (permalink)
blunts415's Avatar
because its an online store.
Old 12-07-2009, 10:00 AM   #6 (permalink)
also any parts store prob has the same rebuild kit just go down there and ask them / see for yourself even call them!!!!!
4 B BODIES
2 SOLD CAPRICES
Old 12-07-2009, 12:48 PM   #7 (permalink)
dintymoore's Avatar
I've only rebuilt earlier ones and the only issue I had with them was removing the pulley. I ended up buying a KD pulley remover tool that I recall was in the $40 range.
You might check to see if that's an issue with your model.
An alternative would be to buy a complete rebuilt one, but even on those there were times where I had to transfer the old pulley as they either weren't supplied on the pump or were different.
Other than that the rebuilds I've done were very easy. Crowsfoot type sockets help to get at the hoses on the car.
dintymoore is offline   Reply With Quote
Power steering fluid Timmyw Chevy Impala 7th Gen Discussion 2 10-14-2009 03:37 PM
power steering pump DIY Loso Autocare and Maintenance 3 09-19-2009 02:01 PM
Power steering Impala66 Impala 1st - 5th Gen Discussion 0 11-19-2008 05:58 PM
94 Camaro power steering issue, replaced pump, and still makes noise? Hyd Automotive Discussion 1 03-06-2008 01:38 PM
How do you take the power steering pump off on a 2000 3.8 impala? JBDizzle Chevy Impala Discussion 1 12-10-2007 01:31 PM
