96 Impala SS odometer cluster problem!!! - Chevy Impala Forums
post #1 of (permalink) Old 09-30-2009, 07:45 PM Thread Starter
mraztek's Avatar
Hello,
well i have a 96 Impala SS and everything works fine last month the odometer cluster was 120XXX miles but sense last week the milage its not showing up! I hear from friends its common problem on this cars, but anyways does anyone know how to fix it? All the cluster gages works fine just the milage doesnt show up nathing!!!!
Any idea can help!
Thank you!
mraztek is offline
post #2 of (permalink) Old 09-30-2009, 10:59 PM
Keylo94SS's Avatar
Hit up Angel from George Bates Automotive he can probably help you out. If not im sure he will know someone who can.
Keylo94SS is offline
post #3 of (permalink) Old 10-18-2009, 07:50 PM
SSanity's Avatar
'96 Impala Odometer Repair Kit
Years ago I had a similar problem. Your odometer is no-longer illuminated most likely because of failed solder joints. Over time, repeated thermal stress from the heat given off by it's resisters causes the failure. There was a write up with pictures on the Region of Doom websight before a server crash. I purchased a kit with directions from Jim Bordelon out of Louisiana. It came with a resister & heatsink and took me 3-4 hours to complete with some soldering required.
SSanity is offline
post #4 of (permalink) Old 10-19-2009, 09:27 AM
fatvet's Avatar
Send a message via AIM to fatvet
Thumbs up fix it
go buy this
http://impalasuperstore.com/supersto...exd.asp?id=694
it is a DIY job......
-ALF out....
'96 WX3 DGGM ISSCA # 01978 #7635 SS on the line http://www.cardomain.com/ride/2386222/1
Bilstein 0929/1104 odom fade mod, FB&HP delete,Pypes-X,Spintech Super Pro Streets, lower bushing mod,Stealth Brake Bolt,Bonnies,SS-Studio TB boot,9C1 air dams
'69 vert stingray
'00 1200C sportster with V&H Straight shots !!
fatvet is offline
post #5 of (permalink) Old 11-12-2009, 03:04 PM
nineSSexy209's Avatar
have the same problem
nineSSexy209 is offline
post #6 of (permalink) Old 01-01-2010, 11:27 AM
gwen's95's Avatar
Hey, Alf, this link is no good.
gwen's95 is offline
post #7 of (permalink) Old 01-01-2010, 01:38 PM
waynes91's Avatar
waynes91 is offline
post #8 of (permalink) Old 01-02-2010, 04:45 AM
fatvet's Avatar
the superstore website got updated so i fixed the link.
the fix is for 96' ss only though...
-ALF out...
'69 vert stingray
fatvet is offline
post #9 of (permalink) Old 01-03-2010, 10:33 AM
bville_boy's Avatar
I wonder if that is the problem I'm having :confused:...odometer changes numbers often, then goes back to the normal. All my dash gauges will light up...WITH MY KEY OUT THE IGNITION...or I was also going to ask if maybe it was a wiring defect and if my car needed rewiring or have my wires looked at.
bville_boy is offline
post #10 of (permalink) Old 01-03-2010, 06:09 PM
94bubble's Avatar
ya i had same prob with my 94 caprice the mileage would go all screwy then back to normal i unplugged my battery for a couple min and i hasnt done it since...
94bubble is offline
post #11 of (permalink) Old 01-04-2010, 03:35 PM
bville_boy's Avatar
No, it's worst than you think ...i has me going gray trying to figure this out...i went by a few shops today and spoke with one guy who said more than likely it's a shortage in my wiring harness or something...now i have to figure out how much is a wiring harness for a '96, i don't know any websites...
post #12 of (permalink) Old 03-14-2011, 07:48 AM
Dril-Dr's Avatar
The odometer on my 96 does the same thing but in the winter when I have the heat on the odometer randomly lights up. Must be something with heat expansion or something???
Dril-Dr is offline
post #13 of (permalink) Old 03-14-2011, 12:45 PM
*ThatBoiFasst*'s Avatar
My Numbers on mine would get all wierd whenever i would have the heat coming out of my vents for a while. the guy i got the car from said that sometimes it gets really hot back there so you gotta put the knob to Defrost, or just blast the cold air to cool it down a little. the first month i had the car it did it a lot, but now i havnt seen it act up in about a month and a half....
*ThatBoiFaSSt*
*ThatBoiFasst* is offline
Odometer problems impalaryder Mechanical and Electrical Problems 14 05-05-2011 11:58 AM
Odometer changes mileage for no reason I presume?! bville_boy Automotive Discussion 8 09-28-2009 01:10 PM
Intermitent odometer ahiggins Chevy Impala 6th Gen Discussion 1 09-11-2009 12:39 PM
digital odometer Targe72 Chevy Impala Discussion 2 12-11-2008 11:16 AM
1996 impala odometer not working 206SS Chevy Impala 6th Gen Discussion 4 09-16-2008 06:05 AM
