Chevy Impala SS Forums
Go Back   Chevy Impala SS Forums > Performance and Technical > Chevy Impala 6th Gen Discussion
Old 05-20-2009, 07:23 PM   #1 (permalink)
TGood's Avatar
Window regulator
Remove this ad!
Whats good everybody? My driver'd window only rolls down partially. It has grooves in the windshield. I think it's the regulator. Has anybody changed the regulator? How hard is it?
TGood is offline
Old 05-20-2009, 08:08 PM   #2 (permalink)
dintymoore's Avatar
It's not that bad. You don't need any special tools, just some patience.
There's a bad design plastic part on my 1992's (it slides in a track) that needs replacement with a newer type round roller, I'm not sure if the later years have that problem.
Sometimes when the power window motor gets old and tired it will only go up part way too, but you can usually tell that the motor is lacking pep.
The only time I've replaced regulators was when some teeth on the sector got worn so they slipped. Usually then the window wouldn't go up the last inch or so.
Maybe try pop the door panel and spray some white lithium grease on the regulator sector and on the regulator fulcrum to lubricate it?
Tri-Flo (which has teflon) works great on regulators too, often they're as dry as a bone.
dintymoore is online now
need help please!! window motor! blairsummit Chevy Impala 7th Gen Discussion 4 07-02-2009 07:42 AM
Window Rattle stevo1390 Chevy Impala 7th Gen Discussion 4 04-11-2009 07:29 AM
Window Tinting oasiswindowtinting Introductions & Welcome Forum 0 12-18-2008 09:54 AM
egr valve (exhaust gas regulator) and a 2000 chevy impala transmission? nathan_842002 Chevy Impala Discussion 0 06-09-2008 04:30 PM
window tint question tph Appearance 2 04-23-2008 12:22 AM
