Chevy Impala SS Forums
Go Back   Chevy Impala SS Forums > Performance and Technical Discussion > Chevy Impala 6th Gen Discussion
Chevy Impala 6th Gen Discussion B-Body 1994, 1995, 1996. Discuss all Chevy Impala 6th Gen Performance and Technical Discussion here.
Old 02-10-2009, 04:41 PM   #1 (permalink)
96SSAgain's Avatar
Steering column question
I bought a steering column (my old one was all jacked out) and putting it in, everything went fine. But when we put the plate that holds it all in, we realized that we had it turned 180 degrees. All the wires fit, everything was fine, but the plate wouldn't fit the way we needed; a turn 180 degrees and it would have been fine.
SO, we looked at the plate and notched out the hole so the plate would fit. That seemed to be the only difference on the plate. Position A had the hole that was now 180 from where it needed to be, so we notched it in Position B. Follow me?
As I've driven it, the column works and everything seems to fine. We haven't hooked up the airbag system yet. I'm going to take it to the local Chevy place and have them check that system out, but I'm just wondering if that plate will cause an issue, or is it fine the way we did it?
96 SS
3.73 rear end...and that's about it
"I don't get it" - pic and statement posted here by UberWagon.
Disclaimer: I'm not knocking ISSF. I read the posts the pic was from. I just think the pic is friggin hilarious.
96SSAgain is offline
Sponsored links
vB code is On
Steering Column Thump/Lube? Wolffy 7th Gen Suspension 11 03-13-2010 04:35 PM
Faint clunk in steering column '08 SS 08RedSS Chevy Impala Discussion 6 10-07-2009 05:02 PM
Can A Cutlass Steering Column fii in a Chevy Caprice? longjames75 Chevy Caprice 1 02-20-2008 03:30 PM
Does anyone know where i can find a steering column for a chevy 79 impala? impala79 Chevy Impala Discussion 3 11-04-2007 09:16 PM
can i use a steering column from a van on a c10 pick up? JAMES T Automotive Discussion 0 09-05-2007 03:00 PM
Sitemap Index - Archive
