Go Back   Chevy Impala SS Forums > Performance and Technical Discussion > Chevy Impala 6th Gen Discussion
Home Register Garage FAQ Members List Latest CL Impala Listings Active Topics Search Today's Posts Mark Forums Read
Old 07-19-2008, 08:21 PM   #1 (permalink)
Bigblockcheyenne's Avatar
Question Vibration help???
Got another question this one has me stumped. I have a 95 impala with 150 thousand miles . Win you are driving down the road at a constant speed it shakes real bad. You can feel it in the seats but not in steering wheel. If you give it gas it stops , same win you let off the gas. I have already rotated the tires and pulled the drive shaft to check u-joints. Everything looks fine. Thanks for any ideas.
Bigblockcheyenne is offline
Sponsored links
Old 07-31-2008, 10:27 AM   #2 (permalink)
ImpalaMan's Avatar
Send a message via Yahoo to ImpalaMan
I would bet that your driveshaft is bent. Try disconnecting the driveshaft from the rear end, rotate the driveshaft 180 degrees and reconnect it and see if that solves your problem. If it doesn't, then you have either a bent driveshaft or bad U-joints.
-ImpalaMan
1996 Impala SS BBB - 198k Miles & Still Rockin' Hard!!!
ImpalaMan is offline
Old 08-15-2008, 06:52 PM   #3 (permalink)
Thanks for the ideas again but,I have already tried this as well as checking motor mounts any other ideas are appreciated.
Old 09-30-2008, 05:58 AM   #4 (permalink)
ImpalaMan's Avatar
You said you've checked your U-joints, but have you had your driveshaft checked at a shop for balance? It doesn't cost much, average price for a driveshaft balance is around $40-60.
Old 09-30-2008, 06:59 PM   #5 (permalink)
RMC
RMC's Avatar
Swap front and rear tires and see if problem is now felt in front wheels.
RMC is offline
Sponsored links
vB code is On
1989 caprice pinion nose is alittle down, does that cause vibration and roughness at Carlos D Chevy Caprice 1 06-21-2008 03:48 AM
Vibration In Gas Pedal, 2003 Chevy Impala ?? The Beaner Chevy Impala Discussion 0 04-20-2008 08:20 PM
2000 Impala, vibration during turning while accelerating.? Cypher's Momma Mechanical and Electrical Problems 2 09-21-2007 12:59 PM
Network of sites: Chevy Impala SS Forums, Dodge Caliber SRT-4 Forums, Chevy Caprice Store, Chrysler Sebring Blog, Dodge Avenger SRT-6, Dodge Caliber Owners, Dodge Challenger Store, Dodge Zeo Concept, GM Ecotec Vehicles, Hyundai Genesis Blog, Kia Borrego Blog, Mitsubishi Eclipse Parts, Mitsubishi Lancer EVO, Subaru Impreza WRX STI, Subaru Justy, Suzuki SX4 Sport. Other Sites: No Fear Brands, Zippo Blog.
eXTReMe Tracker
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Sitemap Index - Archive
