94 caprice runs cold all the time what can it be? Also my windows roll dow... - Chevy Impala Forums
post #1 of (permalink) Old 05-21-2008, 11:49 AM
texazpitz
texazpitz's Avatar
Quoted: Post(s)
...crooked or "fall" crooked. my car never warms up on the temp. gauge. it is an 4.3L LT1 i know it has a reverse cooling system meaning my heads is the first place the coolant runs throught can it be my thermostat? also my windows " fall out of track" so to speak. is it a pin? or something broke? parts numbers would be helpful.
post #2 of (permalink) Old 05-21-2008, 11:49 AM
guess78624
guess78624's Avatar
Quoted: Post(s)
First of all is the radiator full? If water falls low enough, it will not touch temp sensor, and therefore will give no temp. reading, -- this is very risky, and if it is low enough, it will "boil",-- and push what is left out,. - and warp heads (or worse)!
If radiator full, then it must be thermostat (stuck open), -- which eventeually would read at least some on temp. gauge!problem described (above paragraph),--could be from a bad pressure cap, - which will let water push out possibly enough so doesn't reach temp bulb! Also water will not get as hot with bad pressure cap!
Waterpump is not probelm ,unless water (pump seal) is letting water leak out and getting below temp bulb as described above, -- If not working at all, "Guranteed" it will get very hot very quick!
post #3 of (permalink) Old 05-21-2008, 11:49 AM
$ CAIN $
$ CAIN $'s Avatar
Quoted: Post(s)
It could be a thermostat,heater core,water pump, or radiator problem, Also check coolant level. Does your car blow out hot or warm air from its heater inside? Your windows fall out of track because your window guides (small plastic clips that clip on to the windows ) have fallen off or gone bad/worn out. replace em cost only a couple of dollars. Just ask a local parts store for window guides for your year and make. Also make sure you have 50 /50 coolant/water
post #4 of (permalink) Old 05-21-2008, 12:52 PM
fatvet's Avatar
Send a message via AIM to fatvet
Cool
FYI 5.7 = LT1
4.3 = L99 at least i'm pretty sure of it......
assuming you have enough fluid go for a ride and then "carefully" touch the hoses to see if they are warm. (2 rad hoses, 2 header core )
if they are warm almost too warm to touch bare handed then let assume flow is good and move on.
if T-stat is over 2yrs old just go buy a new one and pop it in (not good to through parts at the car but this should be fine and not break the bank)
test drive again, if the guage in car still dead then try to test the sensor, it's in the pass side cylinder head, close to firewall i think. (maybe time to scan pcm for codes ??)
Or through parts at it with a new sensor and test drive again.
you need to start ruling the easy things out.... Good Luck
-ALF out....
'96 WX3 DGGM ISSCA # 01978 #7635 SS on the line http://www.cardomain.com/ride/2386222/1
Bilstein 0929/1104 odom fade mod, FB&HP delete,Pypes-X,Spintech Super Pro Streets, lower bushing mod,Stealth Brake Bolt,Bonnies,SS-Studio TB boot,9C1 air dams
'69 vert stingray
'00 1200C sportster with V&H Straight shots !!
fatvet is offline
post #5 of (permalink) Old 05-22-2008, 06:50 AM
KW Baraka's Avatar
....it is an 4.3L LT1......
How much ya wanna bet :frown: ?
KW
1996 Impala SS and 1995 Caprice 9C1
KW Baraka is offline
post #6 of (permalink) Old 05-22-2008, 02:27 PM
COLD STEEL's Avatar
I am somewhat of a "mechanic" so I will say, the fellas here are right when they point out that you 4.3 liter 200 hp L99 is Not the 5.7 260hp LT-1
As for your windows, its a very simple fix that requires taking off the door panel and inspecting the metal rail to find which plastic piece broke so you can replace it. I actually have those made for me and I sell them as well as repairs for the locals. Does not take much of anything as far as time and money go.
COLD STEEL is offline
post #7 of (permalink) Old 09-29-2008, 12:01 AM
samshiimpala's Avatar
firs, your water temp sensor isnt even on the reservoir... its on the passenger side of the block at the bottom, near the knock sensor. secondly... your tem gauge would read somthing even if your thermostat wasnt installed. so i would guess you either have a broken wire, a bad sensor, or a bad gauge.
samshiimpala is offline
post #8 of (permalink) Old 12-14-2008, 11:21 AM
BYB_CUZ's Avatar
Order a window fix kit from impalassuperstore. Your cooling problem would be first to check level, then if lower than normal, check for leaks. Easiest way for me to spot a leak is too look for any tan stains anywhere.
BYB_CUZ is offline
How much do a 1976 Caprice classic runs including the ones with 24 inch rims? Saint Chevy Caprice 0 06-21-2008 05:32 AM
What time is the best time to trade in your 2008 chevy impala? my credit tyrone j Chevy Impala Discussion 1 05-22-2008 07:09 AM
I have a chev 2001 impala that wont' start from time to time.? reneeandrews83 Chevy Impala Discussion 0 04-17-2008 11:18 AM
I have a 1991 Chevy Caprice 305ci runs poorly? Frederick B Chevy Caprice 8 02-20-2008 02:30 PM
1991 chevy Lumina,3.1.Starts from cold,runs until it warms up then dies.What do... Rock Quarry Automotive Discussion 2 09-03-2007 06:21 PM
