1994 5.7 liter LT1 Chevy Caprice stationwagon rotates, but won't start.? - Chevy Impala Forums
Old 04-27-2008, 07:16 PM   #1 (permalink)
jasondee
jasondee's Avatar
I just replaced the Optispark rotor and cap, and now have fire at the plugs. It started and ran, but I would have to push the gas easy for it to stay running and not shut off. If I pushed the gas more than just a little it would stop running. It was doing this one day before I wasnt getting spark and replaced the cap and rotor. Now it will not even start again, but there is spark, and the fuel pump is working. I didnt check the fuel pressure with a gauge. I did jump the fuel pump and pressed the relieve valve in the gas line. Gas sprayed out well, but that's all I know.
  Reply With Quote Quick reply to this message
Old 04-27-2008, 10:56 PM   #2 (permalink)
9c1 newbee's Avatar
Check the fuel pressure with a guage. I am thinking it should be around 60psi but I could be off.
http://Jasonholden.selfip.com
<-------- Where the hot females hang out.
9c1 newbee is offline   Reply With Quote Quick reply to this message
Old 04-28-2008, 12:41 AM   #3 (permalink)
Goldmaster's Avatar
Fuel pressure should be between 38-45lbs. Any less than 38lbs and you got problems... Also, make sure that you put all the plastic intake pieces on tight an there are no leaks. An air leak downstream of the mass air flow sensor could cause the car to stall or not start. Another thing to check is the 3 ground wires at the coil. The wires/eylets have a tendency to get brittle over time, and can break easily if they were disturbed when you replaced the opti...Good luck
---------------{ 1994 Buick Roadmaster 250K }---------------
---------------{ 1995 Buick Roadmaster 135K }---------------
Goldmaster is offline   Reply With Quote Quick reply to this message
does a 92 chevy caprice stationwagon have a self leveler? gatorfan1 Wagon Discussion 2 05-12-2008 06:05 AM
1994 Caprice LT1 wants to start running only after I stop cranking it, but doesn't? jasondee Chevy Caprice 2 04-29-2008 02:56 PM
1994 5.7 liter LT1 Chevy Caprice won't start? jasondee Chevy Caprice 5 04-27-2008 07:17 PM
Why will my 1994 Chevrolet Caprice Classic not start? shannon Chevy Caprice 1 02-21-2008 05:00 AM
i got a 2001 chevy, 4.3 liter , 6 cyl, hard to start....? angela h Automotive Discussion 0 09-09-2007 12:04 PM
