Why is my engine light comming on and off for my '87 Chevy Caprice? - Chevy Impala Forums
post #1 of (permalink) Old 04-14-2008, 09:20 PM
W A
W A's Avatar
Quoted: Post(s)
I have a 1987 Chevy Caprice Brougham and the service engine soon light started to come on but when you turn off the car (going in to a store etc.) an start the car again the light is out.
Why would it do that?
Also the passenger’s side mirror will go up and down but not side to side.
Answers would be greatly appreciated.
post #2 of (permalink) Old 12-05-2009, 01:36 PM
mnkelly's Avatar
Talking mnkelly
Could be the PCV valve is bad or the vacuum hose or port is plugged. This happened to my 1990 chevy 350 TPI. The port in the throttle body was completely plugged and the service engine soon lit would come on after I drove it for a while. Usually the SES light is related to an emmision component so you should concentrate your search in those areas first.
mnkelly is offline
post #3 of (permalink) Old 12-05-2009, 03:12 PM
77Impala's Avatar
Quoted: 6 Post(s)
Your 87 is a OBD-I system. It does not store the code past when you turn off the key in most cases. It does keep coming on due to self test showing that an emission system part is out of specs. Best to find someone whom has the ability to read the OBD-I codes and have that person read the code before the car is shut off next time the light is on. Most auto parts stores only read OBD-II (96 and newer) codes. Some may have a reader that can check the older cars.
Passenger side electric mirror could either be a faulty switch, broken wire for the up/down motor, or failed motor. Testing would have to be done to track down the problem.
1977 Chevrolet Impala Sedan
1989 GMC C1500 Sierra ECSB
77Impala is offline
post #4 of (permalink) Old 12-05-2009, 05:13 PM
77Impala's Avatar
Quoted: 6 Post(s)
Just now noticed that this thread is over a year and half old.:tongue: Hope he has it fixed by now.
77Impala is offline
post #5 of (permalink) Old 12-06-2009, 06:51 AM
RMC
RMC's Avatar
Send a message via AIM to RMC Send a message via Yahoo to RMC
Doesn't this year still respond to shorting the A and B pins together on the computer diagnostic connector under the dash and getting a flashing SES light with the stored codes? Also, I do remember that some codes are stored for a period of time after the SES turns off.
RMC is offline
post #6 of (permalink) Old 12-06-2009, 04:44 PM
77Impala's Avatar
Quoted: 6 Post(s)
Yes it does. With my code reader that I use regularly I forgot that this could be done.:redface: Anyway the code reader makes the task so much simpler than having to count the flashes.
77Impala is offline
Help with my 2002 Chevy Impala with engine light ? TAG Chevy Impala Discussion 1 09-13-2008 05:48 PM
check engine light for chevy impala 2002? Sam S Chevy Impala Discussion 1 07-08-2008 01:51 AM
Check engine light on a 2002 Chevy Impala? Mom_to_2! Chevy Impala Discussion 2 06-18-2008 12:23 PM
I have a 2004 Chevy Impala and the check engine light just came on. The car is... Dave W Chevy Impala Discussion 6 05-11-2008 09:52 AM
How do I reset the serive engine soon light in a 02 chevy impala? rebel_slash_hippy Chevy Impala Discussion 2 03-23-2008 06:36 AM
