78 Caprice wiring - Chevy Impala Forums
Old 08-22-2012, 06:58 PM   #1 (permalink)
78 Caprice in Oz's Avatar
78 Caprice wiring
Hi, have some wiring issues with 78 Caprice, main problem is tracing wires from one end to the other through the loom, eg: internal lights work from headlight control but not from door jam switches , a circuit diagram would be a big help, if someone has one for this car.
78 Caprice in Oz is offline   Reply With Quote
Old 08-29-2012, 05:23 AM   #2 (permalink)
Have managed to fix my internal lighting problem, my next problems to fix are: Heater only blows cold air, does any one have any ideas as to what could be going on, or how the heater system works as it's a combination of electrical and vacuum, which is something i haven't seen before.
Second problem is the washers run all the time that the wipers are running, the pump isn't the usual 12v pump in the reservoir but instead a mechinal one attached to the wiper motor with a ratchet and with 5 wires plugged into it???? Any help will be appreciated.
Old 08-29-2012, 02:18 PM   #3 (permalink)
77Impala's Avatar
Glad you fixed the dome light problem.
Heater blowing only cold air is most likely the heater core plugged up which you can change out under the hood. Least likely problem may be that the temperature control cable is not connected to the blend door. You will find the blend door behind the glove compartment and it should have the cable attached to it.
Wiper washer problem will require a new washer unit which bolts up to the wiper motor. I have changed a few of them out on my car. They last about 1 to 2 years before going bad again.
1997 Dodge Ram B2500, 5.2L, 36RH, 3.21:1, 374K miles, 24 Lifetime Warranty Parts.
Caprice rear lights wiring Old Bones Restoration Forum 1 09-28-2011 07:08 PM
86 Caprice cluster wiring chart DeVilleL13 Chevy Caprice 0 09-30-2010 02:40 PM
1996 Caprice 4.3 Wiring Help (unplugged connectors where to?) cyteone Chevy Caprice 8 11-23-2009 09:09 PM
Hot wiring a 94 caprice Etrackstar Chevy Caprice 2 07-19-2009 08:30 PM
1995 caprice 9c1 wiring harness and ecm jmreaper Private For Sale Classifieds 0 03-02-2009 11:48 PM
