Best Wheel size for my ride? - Chevy Impala Forums
Old 07-14-2012, 09:47 PM   #1 (permalink)
hishiad's Avatar
Just wanted to get some opinions. Right now it's got 15's on it (factory/stock wheel). I'd like to get a bigger wheel, but I don't want to have to modify the vehicle any to fit the wheel and I don't want to require new parts for the larger wheel... So I guess basically what is the largest wheel size I can get away with while staying stock?
1985 Chevrolet Caprice
Bolt Pattern (in): 5x5.00
Bolt Pattern (mm): 5x127
Offset Range (mm): -10 to 10
Front Center Bore (mm): 78.3
Rear Center Bore (mm): 78.3
Stud_Size: 12x1.5
hishiad is offline   Reply With Quote
Old 07-16-2012, 10:13 AM   #2 (permalink)
First off, bolt spacing is 5x4.75, not 5x5, they didn't switch to that pattern till 91. As long as your overall tire diameter, and wheel backspacing doesn't change, your options are whatever you want. You will easily be able to fit 18x8's with no issues, probably even 20's.
Old 07-16-2012, 03:35 PM   #3 (permalink)
hishiad's Avatar
Thanks for the correction, I was using the website "My Bolt Pattern"
Old 07-16-2012, 04:37 PM   #4 (permalink)
Most of them are wrong I've noticed, but yeah, 77-90 are 5x4.75, 91-96 5x5. Other than that, they are the same.
Old 07-29-2012, 09:37 PM   #5 (permalink)
hotrodjunky1982's Avatar
i run 20x8.5 with 245/45's all around. no rub even with a 2" drop. i could go even bigger out back. i have pics in various posts
hotrodjunky1982 is offline   Reply With Quote
Old 07-29-2012, 10:45 PM   #6 (permalink)
Jd1
The F*** Killer
Jd1's Avatar
http://www.impalaforums.com/impala-1...e-cheaply.html
This should work. By the way your car looks sick, and the comment about the fat chicks is priceless, LOL!
Purchased:
1/3/12
09 Impala LT
Installed:
Alarm/Starter, 35% Tints, Black BowTie, Debadge, Trunk Lip, Window Visors, 18X8.5 Gunmetal/Polished ADR Battle EXE 245/45/18, 15MM Rear Spacers, Ebay Lowering Springs 1.7In, Monroe Struts & Mounts, Shorted Dog Bone, H.I.D 55W Ballast W/ 35W 5K Bulbs, Retrofit Black Headlights.
Future Mods:
Black Roof
Jose
Jd1 is offline   Reply With Quote
Old 07-30-2012, 10:55 PM   #7 (permalink)
thanks for the complement!
Old 07-31-2012, 04:41 AM   #8 (permalink)
I believe the 80s 9C1 got the 5on5 pattern too, might be the source of some "bad info" in some places.
1969 wheel size? creep Wheels and Tires 8 01-21-2011 08:41 PM
Funky steering wheel puller size? gtaylor Restoration Forum 7 11-14-2010 11:12 AM
Wheel size!? Edbean Wheels and Tires 11 11-02-2009 06:24 PM
Original Wheel Size Systematic Chaos Impala 1st - 5th Gen Discussion 3 09-29-2009 09:08 PM
Factory Wheel size Systematic Chaos Wheels and Tires 0 08-27-2009 03:33 PM
