I wanna make my 5.0 GO FASTERR! - Chevy Impala Forums
Old 01-29-2012, 03:45 PM   #1 (permalink)
RainMan2011's Avatar
Talking I wanna make my 5.0 GO FASTERR!
MY first post i have a 1993 caprice with a 5.0 i need any hints, tips, tricks little things that will make my 1993 move her ass a little bit faster, thanks
RainMan2011 is offline   Reply With Quote
Old 01-29-2012, 04:13 PM   #2 (permalink)
& Barricade
Papa D's Avatar
Intake and exhaust will be the first things you wanna address. I am not real familiar with the 5.0. is this a TBI engine?
Jackass of all Trades
Tri-9 Defined: 1994, 1995 or 1996 B-Body.
1994 9c1- 300,000 miles and counting.
Papa D is offline   Reply With Quote
Old 01-29-2012, 05:51 PM   #3 (permalink)
2011LSKING's Avatar
Since when did gm and Chevy use a 5.0 engine......I thought that was Ford
2011LSKING is offline   Reply With Quote
Old 01-29-2012, 06:31 PM   #4 (permalink)
The 5.0 was a 305, it was used I think mostly from 77 all the way up to 93. Should be a TBI. Depends what your goals and budget are, that motor doesn't have a whole lot of potential, but some things you can do would swap over if you wanted to get a 5.7 later, like exhaust. Sticking with what you have, best bet would probably be to throw a cam in it.
Old 01-30-2012, 12:30 PM   #5 (permalink)
Kapital_Caprice's Avatar
The 305 engines are Chevy's 5.0s
I'm looking to do the same thing in my 87 Caprice and plan on putting a new Carb, Intake Manifold, Cylinder Heads, and Cam, and dualing out the exhaust to let it breath. In a 93 however you probably have TBI so I guess some of the options I'm looking at wouldn't benefit you.
Kapital_Caprice is offline   Reply With Quote
Old 02-04-2012, 09:07 PM   #6 (permalink)
Gregg-O's Avatar
With that amunt of work, why not just do a crate 350?
If you have fear of some pain or suffering, you should examine whether there is anything you can do about it. If you can, there is no need to worry about it; if you cannot do anything, then there is also no need to worry.
Old 02-04-2012, 10:17 PM   #7 (permalink)
cbtlr's Avatar
^^^^^ WELL SAID get a 350 cid and let the build begin..More cubes more potential..No use throwing that money in a 305 when you can build a 350 at the same price for WAY more performance..
cbtlr is offline   Reply With Quote
Old 02-04-2012, 11:02 PM   #8 (permalink)
Caprice Classic with Class
Old Bones's Avatar
Forget spending any amount of cash on your 305. Instead save up some cash and go for one fo these like I am.
350 Crate Engine 330HP (Deluxe) HO Turn-Key 19210009 - Crate Engine Depot
Turn-Key ZZ4 Crate Engine 350CI 355HP HO with Accessory Kit And More 19201330 - Crate Engine Depot
1983 Caprice Classic.
350 CID. 330 HP. 380 Ft.Lbs. Torque. Turbo 350 Trans. with Cooler.
Headman Headers. Magnaflow Cats. Flowmaster Delta 50 Mufflers.
Electric Fan. Compu STAR Alarm. Crazy Canuck behind the Wheel.
Old Bones is online now   Reply With Quote
Old 02-06-2012, 08:41 AM   #9 (permalink)
As you can see the clearly easier and more logical answer will be just getting a 350 lol. I'm only keeping my 305 for the challenge and the fact I don't like to do the norm. But honestly a 350 will make your car ALOT faster from stock and upgraded. But this really all depends what you want out of you're car performance wise? My car is just gonnabe a cruiser for me.
Old 02-06-2012, 08:50 AM   #10 (permalink)
Old Bones's Avatar
I don't hate my stock 305 , it always starts , runs well , but it's a slug.
IMHO beefing it up is a waste of $$ when a 350 (same block) will fit right in and double your horsepower.
Old 02-06-2012, 11:12 AM   #11 (permalink)
Exactly, same size and weight, why not? I'd like an engine from Steve Morris, but that's kind of a higher price range...
Old 02-19-2012, 08:52 PM   #12 (permalink)
ponchoman49's Avatar
My best friend had a 1986 coupe with the LG4 305 4BBL engine rated for 165 HP and we were pretty happy with it's performance overall. It was a low 62K mileage car owned by an elderly guy who kept it perfectly maintained. It had the optional 2.73:1 rear gears in place of the stock 2.56 setup ordered that way from the factory as a $21.00 option along with the equally dirt cheap 41.00 F-41 suspension. I did a few tweaks to the carb on the secondary side, ran a slightly cooler plug and t-stat to keep the 305 from pinging which has the adverse affect of dialing back timing and power and ran a K&N filter. The biggest performance booster was replacing the stock cat converter with a Magnaflow unit to take advantage of the extra carb flow. It wasn't a race car but hardly a slug and it would easily light up the rear tires. Another thing to pay very close attention to on stock C4 equipped 305's is the TPS sensor. If it is even off slightly you will lose power and response along with erratic and or late lockup torque converter lockup in third and 4th gear. A GM service manual is a must with these often misunderstood cars. They are getting pretty old now and things need replacing/rebuilding and checking.
ponchoman49 is offline   Reply With Quote
Old 02-20-2012, 06:12 AM   #13 (permalink)
The Unscrupulous Lt. Colonel
Crime Scene's Avatar
If it helps any, its guys here in Lagrange Ga that builds Chevy motors and Chevy Motors only for a living. Ive seen them use a set of 350 heads on a 305 block, and a lot of the 305s they built has put a lot of 350's to shame. IMHO, if the 305 equipped car can sit for a while and the owner although could easily opt for a 350, but rather enjoy the challenge of building the latter, then i say throw some 350 heads on there and lets see what you can do....
2001 Chevy Impala 3.4 - Traded
2004 Chevy Impala 3.4 - Traded
2002 Chevy Impala 3.4 - RIP 1.12.2011/ Ice Storm
1996 Chevy Impala SS - RIP 4.15.2012/ Asswipe
1996 Chevy Impala SS - Current
Crime Scene is offline   Reply With Quote
Old 02-20-2012, 10:28 AM   #14 (permalink)
The main difference between the two is size, there is no reason that whatever mods you do to the 305 that make it beat a 350, wouldn't make that much MORE power when done to a 350 instead. Plus they don't cost any more, and they don't weigh any more, not a hard choice if you ask me.
Old 02-20-2012, 07:33 PM   #15 (permalink)
Gregg-O's Avatar
Can we beat this horse anymore?.............
wanna make my 96 ss fast any good ideas? Nalessard11 Automotive Discussion 9 04-28-2010 02:59 PM
Anybody In Md Wanna Setup A Meet cudablack2004 Mid Atlantic 3 03-27-2010 08:56 AM
new here just wanna say hi capala22 Introductions & Welcome Forum 4 12-22-2009 07:30 PM
Not Impalas but I still wanna show 'em off cbmikey Media Bucket 5 09-22-2009 01:32 PM
I wanna be an Impala obrian Introductions & Welcome Forum 2 04-13-2009 06:22 PM
