Brake Lights stopped working... - Chevy Impala Forums
post #1 of (permalink) Old 01-10-2011, 06:06 PM Thread Starter
akoimeexx's Avatar
Send a message via AIM to akoimeexx Send a message via Skype™ to akoimeexx
Ok guys, I'm stumped.
My 96 Caprice had perfectly normal brake lights yesterday, and today, they stopped working. The lights are fine (checked on a separate voltage supply), but I'm getting no voltage from the brake pedal switch back. All of the fuses are fine, but with the mess of police-innovation wiring, I can't tell which fuse goes to the brake pedal switch to isolate where my loss of power is from. Anyone have any experience with this?
[ '96 Caprice 9c1 | '84 Honda Magna | '85 Honda Interceptor EV ]
[ DIY: Air intake plug | DIY: HID Install | Ceiling console mod: coming when I get new ceiling upholstery ]
akoimeexx is offline
post #2 of (permalink) Old 01-10-2011, 06:23 PM
77Impala's Avatar
Quoted: 8 Post(s)
If you have power coming into the brake pedal switch then the fuses are fine. Now after the brake pedal switch since our Impala's use the same bulb for either brake or turn signal the brake wire goes to the signal switch. So now then the most likely problem is in the turn signal switch unit on the column. Do the turn signals work correctly?
1977 Chevrolet Impala Sedan
1989 GMC C1500 Sierra ECSB
77Impala is offline
post #3 of (permalink) Old 01-10-2011, 06:30 PM Thread Starter
akoimeexx's Avatar
Turn signals work fine, but I don't seem to have any power from the brake pedal switch itself. I'm going to try to check from the hot line to the brake pedal switch to a ground point on the frame next and post back when I have the results.
Edit: Yep, I've got power to the brake pedal switch. So, what next if the turn signals are working?
post #4 of (permalink) Old 01-10-2011, 06:36 PM
77Impala's Avatar
Quoted: 8 Post(s)
Does the power transfer across the switch when the pedal is depressed? If not then the switch has failed. If power transfers across then look up inside the column at the turn signal switch.
77Impala is offline
post #5 of (permalink) Old 01-10-2011, 06:40 PM Thread Starter
akoimeexx's Avatar
Power transfers correctly, with the old switch and the new switch. Seriously though? The turn signal switch? >.<
post #6 of (permalink) Old 01-10-2011, 06:47 PM
77Impala's Avatar
Quoted: 8 Post(s)
Yes since it makes the "decision" whether to flash the bulb or leave it steady on. And all this is based on the position of the signal lever with or with out the brake switch on. Since neither side is working (brake lights) then either the wire from the brake pedal has fallen off the turn signal connector or the switch internal connection point has failed.
77Impala is offline
post #7 of (permalink) Old 01-10-2011, 06:59 PM
77Impala's Avatar
Quoted: 8 Post(s)
Come to think about it I have seen one vehicle where the brake switch would transfer power for a DMM but not for the lamps. I found it by jumping the connector with the switch removed and lite up the lamps. Might try that.
Also does the 3rd lamp work on your car? Many ignore it or disable it. But if it had worked then recheck its bulb for it might be blown now and not light up when the pedal is pressed. (DISCLAIMER: the third lamp [one in the back window or on the spoiler] does not need to work in order for the standard brake lamps to work.)
77Impala is offline
post #8 of (permalink) Old 01-10-2011, 07:11 PM Thread Starter
akoimeexx's Avatar
Ok, so it looks like I'm done for the night then; I don't have a lit garage and tearing apart the column to get to the turn signal assembly is not my idea of a good night time activity.
I'll post more tomorrow.
post #9 of (permalink) Old 01-10-2011, 07:14 PM Thread Starter
akoimeexx's Avatar
Nope, the center light hasn't worked since I got the car. I plan on (eventually) replacing it with a Larson scanner with a switch in the ceiling console, but that's a trivial issue compared to actually having the car road-legal.
post #10 of (permalink) Old 01-12-2011, 12:38 PM
thacarter546's Avatar
Sounds like your saying you have power before the brake switch, but not after when the pedal is depressed. Wouldnt that just be the brake switch?
Also could it possibly be a bad flasher? When I was swapping out to leds I had nightmares. I would get the bulbs to flash once then itd all go dim.
thacarter546 is offline
post #11 of (permalink) Old 01-12-2011, 12:51 PM Thread Starter
akoimeexx's Avatar
Ok, updating while @ work:
I have already placed the (still working) brake pedal switch, and that wasn't the issue. I have power after that to the turn signal switch. All other lights work, including turn signals. Aside from the HID upgrade (brake lights were still working after that, and have been for a while), nothing else has changed.
Tore down the panels from the steering column, removed the security plate, and plugged in a new turn signal assembly to test if the one in the car was bad. I still have no brake lights. Returned the turn signal switch assembly and now it looks like it's just going to be tracing a crap-ton of wiring... unless anyone else has any ideas if there's some other unit that the power goes through before hitting the brake lights?
In the meanwhile, I'm stuck borrowing a car until this is fixed.
post #12 of (permalink) Old 01-12-2011, 01:10 PM
If you dont have one already it might be in your interests to buy a short finder (dunno what theyre actually called) Harbor freight, mac, and snap on all have them, hooks into the wire your testing, then you trace it with a handheld unit and if there is a short it will beep in the vicinity of the short. Can save hours of time.
HIDs would have nothing to do with it. Ive had mine in a month after I bought the car.
I still think the flashers may have something to do with it. Ive tried pretty much all of the available flashers for our cars and the only one that worked for me (all LED lighting and still had to make a load resistor) was the Bussman super heavy duty variable load. Avalable at blowreillys I mean Oreilly Auto Parts. Dont waste your time on the Tridons or the factory replacement BWD. When I used these I had no brake lights or turn signals.
post #13 of (permalink) Old 01-12-2011, 01:54 PM Thread Starter
akoimeexx's Avatar
Why would it be the flashers if I still have turn signals & hazard lights? Wouldn't it stand to reason that both units should still be good?
I'll look into a short finder, or whatever they're called though. Sounds like it'll save a ton of grief.
post #14 of (permalink) Old 01-12-2011, 04:57 PM
77Impala's Avatar
Quoted: 8 Post(s)
A short tester will help. Also a good 12 volt test lamp, even a home made one will be helpful. I would test the power going into the brake pedal and then at the turn signal switch with a 12 volt lamp. Like I said in a post earlier I did see a switch that had power coming in and out but had internal resistance to the point that it could not provide enough amps for the bulbs. In this case I am wondering if you have sufficient current to power the bulbs.
I do not follow the flasher unit theory pointed out above.
77Impala is offline
post #15 of (permalink) Old 01-12-2011, 05:03 PM
77Impala's Avatar
Quoted: 8 Post(s)
Wonder if anyone has a wiring diagram for your car that they can share. Your turn signal switch should have at least two power sources. One from the key on position and second form the brake switch when the pedal is depressed.
77Impala is offline
bad smell from vents and fan switch stopped working chnike Chevy Impala Discussion 5 05-29-2013 10:51 AM
2003 Interior lights stopped working after BCM change. mrwildbob Chevy Impala 7th Gen Discussion 8 02-13-2011 04:17 PM
Turn signals & brake lights stopped working Plaigh Chevy Impala 7th Gen Discussion 5 10-14-2009 03:56 PM
RPM Gauge stopped working and problem with my headlights.... snwbrdrugbychica8 Automotive Discussion 1 12-28-2008 06:14 AM
I have 1992 Buick Roadmaster - the rpm stopped working. Is it a fuse..or what is it? Linda D Buick Roadmaster 1 03-24-2008 12:01 AM
